Off Road Driving/Fog Lights
Old Dec 24, 2012 | 08:43 AM
mr inspector's Avatar
Just had ranchhand grill guard installed and wanting to complete the look with driving lights and fog lights from PIAA up front. Two fog light housings and two driving light housings, all with 55watt bulbs. Should I be concerned with the added electrical needs on stock system? Is there an alternator upgrade for our trucks? Should I consider better batteries?
Thanks in advance!
Old Dec 24, 2012 | 11:22 AM
.boB's Avatar
You won't be using all four lights at the same time. Adding the driving lights with the high beams or the fogs with your low beams and factory fogs won't create enough of a load over stock to make a big differance. I run two 100W lights with my high beams, and the stock system doesn't have any problems at all.
Now if you add multiple lights and battery charging from a trailer, then you might be overloading the system.
Old Dec 24, 2012 | 12:11 PM
torquefan's Avatar
Good advice above. Just make sure your add-on lights aren't powered through any existing lights on your truck. Use relays and draw power from the battery or close to it. Our alternators will put out in excess of 140 amps, so they will handle pretty much whatever you can think of.
Old Dec 24, 2012 | 02:57 PM
verdesardog's Avatar
two 100w and two 55w, no problems at all.
Old Dec 24, 2012 | 06:20 PM
Rollin'_Coal's Avatar
Same as said above, use your factory high beam wire to turn on a relay and run a heavier gauge wire to your lights and you will be fine. Have you considered LED? I put a 120 watt 24" light bar on my front bumper and it is simply amazing. Go on eBay and do a search for "Wonderfour" they have great prices, seem to be really good quality and they shipped me a full replacement for a very minor problem no questions asked. It is insanely bright and very good offload.
Old Dec 31, 2012 | 12:29 PM
rootkit's Avatar
I just finished my Hella 700f to HIDs 55w. Then I plan on getting LEDs for the fogs since I'm running a tube bumper.
You can run projectors in the front with HIDs and not blind everyone on the road...
fjbiker86
37
Dec 9, 2007 07:29 AM
msatow
Sep 27, 2006 07:32 PM
durasmack
13
Dec 14, 2004 08:29 AM
xj2extreme
Jul 1, 2003 03:45 PM
deere nut
Dec 19, 2002 02:46 PM
