OD Lockout switch on 05 ??????
Old Aug 17, 2007 | 03:43 PM
wildchild97's Avatar
Is it possible to lock OD out with a toggle switch? Similar to that of a TQ lockup switch.. I have been pulling in low 1st and shifting to 2nd, i need some more speed...I need to be able to stay in 3rd gear...when i shift to D i go to 4th gear.......Thanks..
Old Aug 17, 2007 | 06:38 PM
bob4x4's Avatar
There is a flash to change the tow haul sw to od off.
Bob
Old Aug 17, 2007 | 07:26 PM
belgianmagic's Avatar
YES THERE IS A TSB... it is well worth it if you tow heavy
Old Aug 17, 2007 | 09:38 PM
sticky's Avatar
BD power also makes a kit so it will perform like the 06' and up trucks. You can select tow/haul or OD lockout with the kit. If you do the dealer re-flash, you will lose tow/haul and only be able to lock out OD like the 04' and older trucks. I don't have the kit but I think it's around $250. and I've read good results on this board.
Sticky
Old Aug 17, 2007 | 09:44 PM
Well i would love to get the flash done but my something is wrong with my OBD II port...cant get anything to come up on a program or code reader...not sure what the prob there is...i have checked all the fuses....I tow pretty heavy with my truck....I have a 40 ft tri-ale enclosed gooseneck race car hauler as well as a 26 ft dual tandom that i haul tractors and bobcats on regualrlly....I was hoping that it was possible to tap into a wire and ground it out somehow....but the BD kit may be the best thing for me......
msiminoff
15
Oct 2, 2012 11:13 AM
Deezil
19
Mar 1, 2011 12:41 PM
Mule Skinner
Jan 12, 2010 11:59 PM
3Sigma
Oct 26, 2006 09:18 AM
Tackett
Jan 30, 2003 04:55 PM
