4wd lockout switch?
Old Feb 23, 2011 | 11:49 AM
Deezil's Avatar
4wd lockout switch?
Tried searching but not sure exactly what its called, but a switch so you can put into 4lo and not have the front hubs lock in for low speed 2wd manuevering, anyone know of such a thing? A buddy told me someone makes one but I cant seem to find it.
THanks
Old Feb 23, 2011 | 01:03 PM
firgod4's Avatar
what the switch i think your talking about does not allow the actuator to lock the front end in so it allows you to have 2 low or 2 high basically.
Old Feb 23, 2011 | 02:14 PM
Deezil's Avatar
yeah
Old Feb 23, 2011 | 02:40 PM
Dick Rector's Avatar
i saw this switch on puredieselpower.com i dont remember how much though
Old Feb 23, 2011 | 03:41 PM
gorms's Avatar
You need a vacuum switch (valve). I'll do some searching, but there was one from a Honda sedan that worked perfect and is cheap to find. Might be better off with a cable actuator.
Old Feb 23, 2011 | 04:14 PM
corliss's Avatar
Try Pacbrake 2 low kit?
Old Feb 23, 2011 | 04:27 PM
corliss's Avatar
Search Pacbrake 2 low kit or www.pacbrake.com, had one on my last Dodge worked great.
Old Feb 23, 2011 | 08:30 PM
Deezil's Avatar
will order up now, got the truck coming!
Old Feb 23, 2011 | 09:29 PM
totalloser's Avatar
www.genosgarage.com is where I got mine. Set it up they way they say and the toggle will make the vacuum actuator flip the CAD vac supply backwards. When toggled and you shift into 4x high OR low it will keep your front axle disengaged. Shift back and it will make the CAD unit grind if you are rolling.
I say don't use them as a 2low device, but simply bypass the transfer case vac valve ENTIRELY and use the toggle to manually control the CAD unit. Now you can have shift on the fly up to highway speeds INSTANTLY in and out of 4x, 2wd low range with a simple shift of the shifter.
The only downside is that to shift from unlocked CAD to 4x4 you need to shift the shifter first THEN lock the CAD. But if the CAD is locked in, 4x shifts in SOOOO smooth and fast!
Old Feb 24, 2011 | 10:53 AM
infidel's Avatar
Just reading the parts list and installation instructions from PacBrake gives you enough info to build your own 2 wheel lo with simple parts for under $50.
Instructions> http://pacbrake.com/PDF/L2033.PDF
Old Feb 24, 2011 | 10:56 AM
Deezil's Avatar
Cool, thanks!
Old Feb 24, 2011 | 11:44 AM
Doj Dewd's Avatar
a posilok cad kit will work too.
search 'posilok psl400' in google.
i have been looking at this recently . . .
Old Feb 28, 2011 | 12:33 PM
justme-'s Avatar
Skip the Posi-lok- I have it- it's trash.
Stripped the cable within 2 months and the replacement cable is 95% of the kit. It's difficult to work the cable- engage or disengage, their instructions for install (cable routing) were wrong - had to wing it. too much resistance their way.
I'm doing a Ford hub swap to get locking hubs instead.
Old Feb 28, 2011 | 06:00 PM
KATOOM's Avatar
Incase you didn't know, the 2 lo kit is ONLY available for the CAD axle trucks.
Old Feb 28, 2011 | 06:15 PM
Deezil's Avatar
Oh man, I dont know what that means. But it came today....
