NV5600 problem Clutch or Gears?
Old Sep 12, 2017 | 12:20 AM
TheNamesTopher's Avatar
Hi there, I have an 05 2500 with the NV5600 and I cant for the life of me figure out whats going on with it. Ive had a reacurring problem I cant replicate. In 5th gear every once and awhile when my tuner is turned up when i give the truck a lot of throttle it revs way up but no power. I dont hear any gears grinding or anything just pure no power until i let off the gas and let it grab. Is this a sign of clutch slippage? I did a stock clutch replacement about 40k ago but I havent been nice too it. The truck has minimal upgrades, 63mm turbo, manifold, intake elbow, banks intercooler, and a edge juice, never surpasses level 3. Any thoughts before i spring on a SB clutch?
Old Sep 12, 2017 | 06:38 AM
deere country's Avatar
Sounds like your engine is walking past your clutch. It's what to expect with a stock clutch and engine mods.
Old Sep 12, 2017 | 07:26 AM
Mexstan's Avatar
Sounds suspiciously like a slipping clutch to me. When this happens, back off on the skinny pedal to give the clutch time to 'grab' and then accelerate a bit more gently. If you can then accelerate with no problem, you can pretty well figure that it is time for a new clutch.
Old Sep 12, 2017 | 10:13 AM
johnh's Avatar
or you can confirm the clutch is slipping by flooring the throttle and holding it there until the smell tells you that it's slipping (5 minutes)
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
