Nv5600
Old Oct 14, 2019 | 05:29 PM
fire5980's Avatar
Question Nv5600
Friends, my 2004 2500 manual transmission is knocking in 6th gear but not at the rpm speed. At 50 MPH, 1500 RPM it knocks (sounds like a small hammer on tin) 100 times in a minute. I've had several local guys drive it and the diagnosis is a tooth missing from the high speed 6th gear.
Any of you fellas experience this issue and if so repair results. Repair or replace transmission?
fire5980
Old Oct 16, 2019 | 11:53 AM
CTD NUT's Avatar
I have a fair bit of first hand experience, unfortunately. I have had teeth fragment off of 6th gear and the counter shaft. It is certainly rebuildable and there is some decent quality aftermarket replacement parts for the 5600 compared to the past.
What you have described sounds like the typical 6th gear teeth cracking and/or breaking.
Old Oct 16, 2019 | 04:39 PM
johnh's Avatar
fire5980
tear it down and then decide!!!
Old Oct 26, 2019 | 07:06 PM
nothingbutdarts's Avatar
Is this a common issue with the 5600?
TIM RYDEN
Mar 28, 2012 10:55 PM
LeonT
Aug 13, 2009 11:57 PM
jayjma20
May 3, 2008 11:06 AM
GOT BOOST?
Apr 19, 2008 06:18 PM
yannick
Feb 20, 2005 11:01 AM
