lugging the motor?
Lugging the engine is when you are in a higher gear and you can not gain speed, hence the low RPM or lugging. So if you are going 50 MPH up a steep grade running 1400-1600 RPM and can't gain speed no matter how much fuel you give it you are lugging the engine. To correct the issue you must downshift to a lower gear.
robert chilton
Aug 8, 2005 08:13 PM
100 Proof
Jun 27, 2003 09:20 PM
