NV 5600 fill plug tool
Old Dec 20, 2004 | 04:39 PM
RonsRig's Avatar
I bought the 17mm Allen wrench from Sears($8) and since I really don't have any other use for it, I was thinking of cutting off the end so that I can use a 17mm socket with it. That way I can torque it and it will take up less room in the tool box.
Old Dec 20, 2004 | 05:01 PM
TXTad's Avatar
Oh, yeah, and having the socket makes it easy to slap my torque wrench on the thing too. (Yeah, I use the torque wrench on everything that has a spec. I'm weird like that.)
Tad
Old Dec 20, 2004 | 05:28 PM
Jerry R's Avatar
Now Ya'll are think'in
Old Dec 20, 2004 | 09:44 PM
CTDinMT's Avatar
TXTad- I'm with you, there's no substitute for quality. Snap-On is overpriced, but their stuff is goood. -Steve
Old Dec 20, 2004 | 09:55 PM
E Wagener's Avatar
Pawn shop 1.00
Old Dec 21, 2004 | 01:35 AM
nickleinonen's Avatar
there are a few things i use a torque wrench on [like engine critical engine work, wheel lugs...]
but for fill plugs, i don't even think about it. if the spec is 20lbs, that is easy to get by hand with a spanner...
if it's something not so critical [like the junk at work] it's air ratchet tight, gun tight [1/2", 3/4", 1" drives] cause it is much quicker. if i am building up traction motor combo's that need the mounting bolts torqued to 1200lbs/ft, it's much quicker to nail the bolts with the 1" gun til it stops turning plus a few seconds... if you do torque them, it's a 2 person job with the 4x multiplier and a 3/4" torque wrench at 300lbs.. and with the floors being not so clean, it's hard to get traction to pull on the wrench
Mikey G
Dec 1, 2006 09:16 AM
TEXAGS'98
Jun 6, 2006 09:04 PM
PapaPerk
Nov 29, 2004 09:13 PM
Ruralmedic
May 13, 2003 08:00 PM
latitud_rt
Oct 23, 2002 10:31 AM
