NV5600 fill plug size
Old Oct 22, 2002 | 09:11 AM
latitud_rt's Avatar
My new truck has only 1800 miles on it. I did my first oil change, greased the only 3 zerks I could find, flushed the fuel filter and checked the axles. My rear axle was alomost a full quart low on gear oil. I used Valvoline 80w-90 and added about 2 ounces of Trans-X, front axle was fine.<br><br>Question: What size is the allen plug in the NV5600 6 speed? Looks like maybe 17mm....<br><br>I have the famous 3rd gear grind and I am thinking that maybe it is low on fluid as well.<br><br>Thanks,<br>Tim
Old Oct 22, 2002 | 02:56 PM
Superduty12v's Avatar
Muted User
Re:NV5600 fill plug size
You might wanna think about changing the fluid in it to some of that high dollar manual tranny fluid that's like $8 a quart... might fix it... might not.. but you'll know you're doing your best to stop it. I highly recommend Redline MTL.
Old Oct 22, 2002 | 03:47 PM
muddymess's Avatar
[quote author=Gear Poet link=board=4;threadid=6140;start=0#56046 date=1035319264]<br>Do yourself a favor -- open up the PTO plate on the driver's side and take out the flat magnet on the bottom of the tranny. Clean it off and replace it, then mount the plate with new gasket sealant. The magnet is effective, and there'll be a lot of break-in metal there. <br><br>GP<br>[/quote]<br>when installing my fastcoolers i was suprised,,,,,,,,no,,,,,,ALARMED at the amount ofmetal in there
Old Oct 23, 2002 | 10:31 AM
latitud_rt's Avatar
What's the easiest way to drain the NV5600? Is the redline fluid a better solution than factory mopar fluid? What about the warranty? ???
dodge35000
Apr 18, 2010 07:56 PM
RAM2940
Jul 30, 2005 11:50 AM
roadranger
Sep 14, 2004 05:10 PM
kevlar
Aug 11, 2004 08:42 PM
Homestead
May 21, 2003 11:30 PM
