Not Enought Heat
Old Jan 19, 2007 | 12:00 AM
iflych52's Avatar
Dealer installed Pac-Brake $1250. A must have item, warms up fast and slows down nice.
Old Jan 19, 2007 | 07:53 AM
Foxborough's Avatar
You want to get the truck warmed up as fast as possible. In the winter diesel tends to get in the engine oil. Driving around with a cold engine is not good. In my last oil report I had 0.5% fuel from city driving. With the winter front my truck warms up noticably faster. JMO
Old Jan 19, 2007 | 12:13 PM
DSLBURNER's Avatar
Mopar offers a diesel burning heater now, and it is slick. The exhaust wraps the oil pan to heat the oil, and it will even turn on the fan without the truck running to defrost the windshield. It is all pre bent metal tubing (fits nice). The exhaust brake will help some. Program the cruise idle system, and run it to 13-1400 RPM a couple of minutes after start up, this will warm it 3 times as fast as 1000 RPM. Some other goog ideas were brought up, like the cheap cardboard front or winterfront. Like someone said, plugging it in helps alot.
NM
Old Jan 19, 2007 | 07:14 PM
FortMacSummit's Avatar
thanks to all. It was really cold here and the truck had not ran for over 2 weeks prior to me taking it out for a drive. I have purchased a winter front for it and will go from there. I will get that exhaust brake.
Cheers
Old Jan 19, 2007 | 09:32 PM
northernwheeler's Avatar
I have the Mopar behind the grill winterfront on mine. Huge difference in engine temps. I highly recommend you get one. Is your truck a stick or auto?
Also get your manual high idle enabled, big difference. You will find these trucks don't make a lot of heat until they are at 1300RPM or so.
Anyway, this works great on my truck, and I am in the same area as you. I work around Marianna Lakes.
tswcoaltrain
Nov 12, 2019 09:11 PM
bkrukow
Apr 29, 2011 06:42 PM
Jethro6213
May 1, 2008 10:43 AM
roughstock
Apr 21, 2008 10:44 PM
dieselfreak21
Aug 29, 2007 10:03 PM
