Normal tranny temps towing
Old Aug 27, 2005 | 07:23 AM
coobie's Avatar
Question Normal tranny temps towing
I was towing my tractor 30hp sub-compact with loader and brush hog on my tandem axle trailer in stop and go traffic,tranny temps were running around 215 degrees according to my BD-X monitor.I had my quad race set in the 60HP position,outside temps were around 81-83 degrees.I was towing on flat ground no hills.When I got back up to highway speeds 55-60 mph the temps went back down 180-190 degrees.My question,is 215 degrees normal while towing in city traffic?What is the Max temp you should look for so you will not cause any tranny damage? I was told not to let the tranny temp get over 230-240 degrees,is this true?Thanks for any info.coobie
Old Aug 27, 2005 | 11:36 AM
jk1364's Avatar
I have seen this temp or more towing my 5er in town (13000 LBS.).Once up to speed 45+ temps drop between 165 and 185 depending on ambient temp. Change your fluid more often as the high temps take the fluid life away. Do a search someone gave some numbers on temp/miles before fluid change.
John
Old Aug 27, 2005 | 11:40 AM
coobie's Avatar
John
I just changed the tranny fluid out with amsoil severe gear oil at 15,000 miles.My truck now has 26,000 miles on the OD.coobie
89dieselkong
Aug 12, 2011 09:07 AM
sleepr tsi
Dec 3, 2008 11:01 AM
keith1992
Aug 5, 2008 10:47 AM
northern puffer
Dec 23, 2003 09:00 PM
RHC
Nov 17, 2003 02:47 PM
