Norm on shut off?
Old Sep 14, 2007 | 05:40 AM
Pav1973's Avatar
Norm on shut off?
Been wanting to ask this for awile now,
When I shut off the engine(temp at the 250 mark) is it normal for it to shake the whole truck? reminds me of a gasser out of timing.
If the temp is low as in the needel is still not moved yet it has no shaking at all.
Pav
Old Sep 14, 2007 | 06:25 AM
vzdude's Avatar
DTR's 'Go to Guy'
Engine temp at 250? Too high for me! The manual trans trucks seem to have more of a shake when shut off. Yours a manual or auto? Try depressing the clutch if it is.
Old Sep 14, 2007 | 06:45 AM
paroxysym's Avatar
my auto shakes sometimes. even when i let her cool for a couple minutes she shakes. its whatever..
Old Sep 14, 2007 | 07:25 AM
Truckman0097's Avatar
Pav
Shaking is normal for Cummins power - but hopefully your engine temp is not at 250, that is not normal - if it is EGTs on the other hand, you have nothing to worry about.
Old Sep 14, 2007 | 07:29 AM
ripping r's Avatar
mine shakes when i shut it off.mine is a 6 speed tho. it shut down like my 98 kw.
Old Sep 14, 2007 | 09:45 AM
donnee's Avatar
Personally, I think it would help to know if your refering to the engine temp or the EGT temp.
If the engine temp is 250, you might have a cooling problem.
My 05 temp usually runs shy of 200 * for cooling and I get a slight shaking on shutdown along with a slight squeak of the fan belt.
Its done that since Iv had it, but I consider it a sign of pure power being stopped.
Old Sep 14, 2007 | 11:36 AM
paroxysym's Avatar
same here..
Old Sep 14, 2007 | 12:21 PM
Roperteacher's Avatar
Mine is a 6 spped, it does shake!! But if you push in clutch it will shake way less then being in Neutral!
Old Sep 14, 2007 | 04:34 PM
hivoltage's Avatar
Mine shakes like a wet dog.....I love it!
Old Sep 14, 2007 | 04:41 PM
leonesm's Avatar
Mine shakes and squeals and usually scares people around it. I replaced the serpentine belt and it really squeals now...
I've heard the high compression of these motors being shut off so quickly is what causes the sound. Perfectly normal
Old Sep 14, 2007 | 05:16 PM
annabelle's Avatar
I assume you are refering to post turbo temps be 250. (Thats fine) You may want to look into the Fluidamper to smooth out the engine shutdown mass.
Old Sep 14, 2007 | 05:43 PM
rjm022's Avatar
maybe he means pyro temp??
Old Sep 14, 2007 | 07:05 PM
purduepurdy's Avatar
She's just wanting to run forever!
Old Sep 14, 2007 | 07:55 PM
masterphreak's Avatar
All the people I work with ask if thats normal when I shut down. I just grin and say yep.
Old Sep 14, 2007 | 11:47 PM
Pav1973's Avatar
Sorry 200(Temp),Had my ford guage in mind not dodge,goes to about 200 maybe a hair over but thats it.
Thx was just making shure,seems this is what vec can breakdown now week for me,I swear I am ready to run my wifes tracker over.
Pav
