No/Low Boost
Old Nov 29, 2008 | 10:33 PM
D45's Avatar
D45
No/Low Boost
All of a sudden this evening I noticed that it was very hard to build boost.
Typically under little throttle the boost PSI will build up to 10-15.....
What can I check?
I drove the truck this morning and the PSI was fine and then tonight it was hard to see 8 PSI (had to really get on the throttle).
I am reading this with a Quad Commander also.
Thanks for any and all info!
Old Nov 29, 2008 | 11:49 PM
megacabdad's Avatar
Is your truck down on power as well?
Old Nov 30, 2008 | 11:50 AM
D45's Avatar
D45
Nope, feels the same to me....
Old Nov 30, 2008 | 12:31 PM
megacabdad's Avatar
Could be your Commander is not reading your actual boost properly then?
Old Nov 30, 2008 | 12:45 PM
trksrfun's Avatar
x2
if your still making the same power then chances are your still making the same boost but its not reading on the gauge for some reason, go back and check the fitting and hose make sure its not stripped, falling out and the line isnt kinked. id start there that would be the easiest fix
Southtowns27
Jul 2, 2011 08:50 PM
jmlcolorado
May 19, 2010 10:30 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
