Need help locating TV cable
Old May 31, 2009 | 08:22 PM
Chippo's Avatar
Have an 05 and have searched this forum and others and can not find the location of the APPS/TV cable to try some adjustments. I looked under the drivers side valve cover, behind the CP3 and around the intake horn, with no luck. I assume it is reached from the top and not under the truck? Can anyone give me a more detail location to find the black cover I should be looking for on a 05?
Thanks
Old May 31, 2009 | 08:28 PM
Rpainter's Avatar
I thought the 05's had the electronic sensor mounted with the throttle pedal. no cable to adjust.
Old May 31, 2009 | 08:30 PM
cameroneod's Avatar
Cant find what you dont have. I believe they quit using them late in 04.
Old May 31, 2009 | 08:42 PM
Chippo's Avatar
Thanks guys....I could not find it, but I have add'l filters just in front of the intake horn. Just trying to find a quick fix to the two step boggie. Have carefully adjust the front band, but that just works for a bit. Have also changed the soleniod and that did squat. Guess I need to do a Supergo kit or greater. Money's tight so looking for a quick easy fix which probably does not exist.
Thanks for the replies
JARHEAD
May 24, 2012 11:05 PM
justagoodolboy
Jun 2, 2008 01:37 PM
inline6359
Mar 26, 2006 09:54 PM
kd460
Jan 24, 2004 04:53 PM
