Need Front & Rear rotor thickness specs for '03 2500 Deisel
Old Aug 9, 2009 | 03:45 PM
Kaysee's Avatar
Does anyone know the minimum thickness specs for '03/2500 Deisel?
I know it's getting harder and harder to find a parts house willing to cut rotors but I need to decide if I need new ones or not.
Old Aug 9, 2009 | 04:28 PM
BigIron70's Avatar
Cummins Guru
Front Disc Brake Caliper Type Dual Piston Sliding
Rear Disc Brake Caliper Type LD Single Piston Sliding
Rear Disc Brake Caliper Type HD Dual Piston Sliding
Front Disc Brake Caliper LD 54 mm (2.12 in.)
Front Disc Brake Caliper HD 56 mm (2.20 in.)
Front Disc Brake Rotor LD 336×28 mm (13.2×1.1 in.)
Front Disc Brake Rotor HD 353×35.5 mm (13.89×1.397 in.)
Front/Rear Disc Brake Rotor Max. Runout LD 0.050 mm (0.002 in.)
Front/Rear Disc Brake Rotor Max. Runout HD SRW 0.131 mm (0.005 in.)
Rear Disc Brake Rotor Max. Runout HD DRW 0.328 mm (0.012 in.)
Front/Rear Disc Brake Rotor Max. Thickness Variation LD 0.012 mm (0.005 in.)
Front/Rear Disc Brake Rotor Max. Thickness Variation HD 0.013 mm (0.0005 in.) Loose Rotor
Minimum Front Rotor Thickness LD 26.4 mm (1.039 in.)
Minimum Front Rotor Thickness HD 34 mm (1.33 in.)
Mininium Rear Rotor Thickness LD 20.4 mm (.803 in)
Mininium Rear Rotor Thickness HD 28.39 mm (1.117 in)
Rear Disc Brake Caliper LD 1x54 mm (2.12 in)
Rear Disc Brake Caliper HD SRW 2x45 mm (1.77 in)
Rear Disc Brake Caliper HD DRW 2x51 mm (2.00 in)
Rear Disc Brake Rotor LD 350x22 mm (13.77 X .86 in)
Rear Disc Brake Rotor HD 353x30 mm (13.89 X 1.18 in)
Brake Booster Type Gasoline Engines LD Vacuum Dual Diaphragm
Brake Booster Type Gasoline Engines HD SRW Vacuum Dual Diaphragm
Brake Booster Type Diesel Engines HD DRW Hydroboost
ldornak
Sep 22, 2011 10:00 AM
schamran
Nov 22, 2010 07:08 AM
phal
21
May 2, 2010 07:15 PM
mr4732
Oct 21, 2007 05:12 AM
06RAMCTD
0
Dec 19, 2006 04:15 PM
