Changing fluids=mess
Old Aug 8, 2009 | 10:07 PM
hamilton71801's Avatar
I changed the oil and fuel filters on my wife's '03 and it was a total mess. It was almost like the engine was pressurized cause when I loosened the oil filter, oil came out and spilled over the sides of the filter. Same with the fuel filter. Definately not like my '01 which doesn't do this. You spin the filters loose and the fluids stay inside and don't make a mess. What gives?
On edit: The fuel filter that Oriellys gave me was too small and wouldn't "lock" into the filter cap (don't know what the part number is but it had an EX I believe and was a WIX). I wound up using an extra that I had laying around for my '01 which had the same part # minus the "EX". Recon it'll be OK?
Old Aug 8, 2009 | 10:19 PM
t-boe's Avatar
Let it sit for awhile. Make sure you drain the fuel filter before you loosen the cap. And once the oil is cool is shouldn't go everywhere when you pull it.
Old Aug 9, 2009 | 07:34 AM
05HDRAM's Avatar
I read it on here - loosen the filter slightly, then slip a ziplock freezer bag over the filter. I had a couple little dribbles from not sealing the bag good once the filter was off, but that was my fault.
I like ordering oil and fuel filters from Geno's. Reasonable prices and quick delivery. I order enough to last a few changes. Always good to keep spares around.
Old Aug 9, 2009 | 07:43 AM
rich's Avatar
you need to use a 7 micron or less on the 03 to keep down the injector wear
Old Aug 9, 2009 | 03:37 PM
05HDRAM's Avatar
I thought the 04.5 and later ran higher pressures ? Not that it matters, all years should now run the 7. I have a supply for a couple more changes, may try the 5 mic Baldwin in the future.
Old Aug 9, 2009 | 04:33 PM
TexasCTD's Avatar
IMO, you are better off if you filter it even finer than 7 or 5.
I run the stock filter (7 or 10, not sure what it is) and then a 2 micron CAT filter behind it and before it goes to the CP3.
PapaPerk
Oct 11, 2006 12:21 AM
Thenewguy
Aug 10, 2006 01:27 PM
Dorkweed
18
Feb 16, 2006 08:34 AM
AggiePhil
32
Mar 11, 2005 10:28 AM
Batoutahell
Jul 12, 2004 11:31 AM
