Rotor thickness
Old Sep 21, 2011 | 11:10 PM
ldornak's Avatar
Rotor thickness
What's the minimum thickness of a rotor that can be turned?
Old Sep 22, 2011 | 09:48 AM
infidel's Avatar
I've had very poor luck as have many others having these rotors turned.
Not all that much more to just buy new ones.
Use the right pads and don't let them rear down to the rivets and the rotors will easily last half a million miles
I use high quality Brembo rotors from www.tirerack.com
Old Sep 22, 2011 | 09:50 AM
Totallyrad's Avatar
Evey application is different. Normally, the minimum thickness is cast or stamped into the rotor. You'll just have to look for it on the rotor.
Old Sep 22, 2011 | 10:00 AM
torquefan's Avatar
2nd gen 4x4 front rotor min thickness is 1.465 inches. If you are going to get them machined, by far the best method is to find a place that has an on-car lathe. Much more accurate than removing this type of rotor and trying to set it up accurately on a conventional lathe.
schamran
Nov 22, 2010 07:08 AM
phal
21
May 2, 2010 07:15 PM
Kaysee
Aug 9, 2009 04:28 PM
KATOOM
Apr 7, 2004 12:12 AM
FastSS
Dec 2, 2003 07:57 AM
