Need advice on engine choice
Old Apr 18, 2004 | 08:07 AM
Harbaw's Avatar
Hello - I'm looking to upgrade to a 2500 CTD. A dealer has an O3' SO auto trans which I think is 215HP/505TQ(?) I like the truck but have a few questions.
1) Seems like I would need to at a perf chip to really get the towing power I need (6,000 - 8,000 pounds). Do you agree?
2) I think I'll test drive a 2004.5 and see how much more powerful it feels than the 03' SO. Seems that a chip in the 03' would make nearly as strong as a stock 600. Is this a safe assumption and are there any reliability drawbacks by adding a chip?
3) MPG is a significant factor for me. I see lots of debate on that but welcome any actual experiences of owners that have owned both engines that I'm looking at.
Thanks guys!
Old Apr 18, 2004 | 08:15 AM
Hounddog's Avatar
I don't think its 215h.p.More like 255 I think.Same h.p.as older H.O.s were.I also don't think towing 6 to 8 k is much weight.Heck WE were towing with 160h.p.versions just a FEW short years ago.I also think a performance box and exhaust etc.will put you near or above the 305/555 with out much problem if the truck is a GREAT BUY! Is it a NEW truck.If so try to steal it from them and go for it.Is it a 48re trans or 47re???What gear etc.
Old Apr 18, 2004 | 09:17 AM
Harbaw's Avatar
I'll get more info, HP/TQ, gear ratio, trans. It seemed smooth, strong & quiet to me at all speeds incl 80 mph or more & the ovhd console was showing some good numbers while cruising empty. They're open today so I'm going to stop by to drive the O3' again and a 600.
It has 17" whls so I think a 4.10 rear would be overkill, right? I doubt I'd tow anything over 10k pounds ever...
Great forum. Thanks!
Old Apr 18, 2004 | 09:55 AM
nirion's Avatar
If it is a non-CA SO, then it is 250hp and 460lb-ft. Tranny on SO is 47RE. The rear end could, and probably is 3.73. 17" wheels are on all 03 & newer. Ram HDs. You will have plenty of power for 6-8k, but adding an Edge EZ will give you comprable or better performance than the HO (it adds upt 70 rwhp & 220 lb-ft). So if you can steal this truck, by all means go for it. As a bonus, no cat as there is on the 600s. Good luck!
Nick
Old Apr 18, 2004 | 02:39 PM
Hounddog's Avatar
If I'm not mistaken EARLY etc.03 S.O.s were 47res.But there was a production chage before 03 ended and the ONLY auto was a 48re and the production of 47s had totatly ended.Check to see WHAT trans is in it.
Old Apr 18, 2004 | 06:11 PM
Harbaw's Avatar
Guys - here is more info. Hopefully some of it is useful to others.
Mfg 6/03, 250hp/460tq, 3.73 rear, 17" whls. Sounds like a pretty potent towing combo (whl size & rear end) especially with an Edge EZ. ** I'd love more input on whether that mod would necessiate guages to watch over the engine/drive train**
Where is the trans ID'd at? I could only find codes in glovebox of DGA / DG8 / DHA & the sales guys on Sundays duty aren't too sharp & didn't know.
I did identical ten mile loops in the 03' SO & the 04.5 600. I was very careful about the driving style & sure enough the 600 was 2-3mpg lower than the 03'. It had a bit more grunt (only at low RPMs, top end seemed the same).
Diesels, especially used, are hard to find here so I think they'll be tough on the price. The MPG difference is a big factor...I'll put lots of miles on it.
THANKS!
Old Apr 18, 2004 | 07:06 PM
dodgedude361's Avatar
if it has the 47re, which i doubt i does, an edge ez might be to much. my brother has a 2nd gen,so, 47re with a VA box, and when towing and pushing the peddle....the tranny slips
Old Apr 18, 2004 | 07:31 PM
Hounddog's Avatar
The Parts or Service guys IF sales can't find the info can pull up a build sheet by the vin number.That will have ALL info such as keyless entry/trans/gearing etc.Get them to print a copy and go over truck and see if all that is listed is the same.
Old Apr 19, 2004 | 04:40 AM
Dodgezilla's Avatar
Just remember that if the truck is still under warranty and you add the fueling box you may end up voiding it. I have a similar truck to what you are looking at except it has 4:10 gears. I towed a 30 trailer this weekend that was probably weighing in at 11-12000 lb and I had no problems moving it 120 miles. I am running the Edge EZ and it makes a big difference in power especially now that I have the 315s on. With these tires I essentially have a 3:73 rear now. I got about 11 mpg towing although the overhead readout showed 14 mpg. If you add the box, the overhead computer will no longer be accurate.....
Old Apr 19, 2004 | 10:04 AM
2003Ram's Avatar
If you get a good deal on it go for it. I have the Ca version '03, stock, and I pull 10-11k through the mountains. On the steepest grades, I have to go to 2nd gear, and run about 45 mph. If I was pulling only 8k, it would never come out of drive.
The truck being manufactured 6/03, it has the 48re, not the 47. Butj for your own peace of mind, make the dealer verify that. On the outside chance it has the 47re, I would not buy it.
For a box upgrade, I'm leaning toward a VA box, but I haven't decided yet.
Check my signature.
Unit44
May 25, 2011 05:34 PM
TOBC
Off Road / 4x4
Jul 16, 2009 10:36 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
bpdp379
Mar 25, 2008 08:30 AM
Israel Sweeney
33
Oct 17, 2006 06:16 PM
