Mystery coolant leak
Old Sep 8, 2016 | 11:51 AM
Mike Lewis's Avatar
04 ram 3500 hundred 24 valve. Coolant around the passenger side oil pan. Radiator is full, recovery about 1/4 full. Checked the clamps on the turbo and they're dry. Water pump is dry, hoses are good
Old Sep 8, 2016 | 11:52 AM
Mike Lewis's Avatar
Oh and no coolant in the oil
Old Sep 9, 2016 | 12:03 AM
westcoaster's Avatar
I think the oil cooler is on the passenger side behind the oil filter.
That may be leaking down the side of the block...
Old Sep 9, 2016 | 12:57 PM
MikeyB's Avatar
There's a rubber flex coupler connecting two hard lines located between the block and turbo. The 2006 models were notorious for leaks from that rubber flex coupler.
Old Sep 9, 2016 | 10:53 PM
Danavilla's Avatar
"There's a rubber flex coupler connecting two hard lines located between the block and turbo"
That hose is a bugger to replace but is a very common leak source. Try just tightening the clamps. That may be enough to stop the leak if that is the issue.
george7941
Nov 28, 2009 09:28 PM
Ram of Steel
Jun 27, 2006 01:06 PM
pet05
Jun 25, 2006 12:55 AM
mx261
Feb 17, 2005 09:56 AM
FMF MX
Dec 9, 2003 02:44 PM
