My truck embarrassed me tonight! Now I need some help...
You know, sometimes these truck just do crazy things like that. I was driving mine down the highway once and it just started bucking and lost power and the CEL came on. I pulled over, cleared the code and it has never happened again.
On my 03, one time, I started the truck and put it in gear and as soon as I hit the accelerator the truck died. I started it and it did the same thing again. Started it again and it worked fine and never did it again. Go figure...
I've been around, just haven't felt spunky lately
Yeah, I'm considering one. Just a little leary of programmers.
Doh!
She did it again!
This time while cruising home on the freeway. Here's what went on:
Cruising at about 75 mph with the Quad X2 on the Mileage Max program I could feel the truck slowly picking up speed. So I lift just a hair and it slows too much, so I feather in a little more throttle and again it picks up too much speed. Again I let off just a touch, and again the truck slows too much. So I add a little throttle, then a little more, then even more but the truck continues to slow. I quickly more to the shoulder and before I make it the truck dies. I immediately check for codes and get nothing! So I start her back up, she fires right away, and I drive home without further incident. But I did notice my lift pressures where jumping around quite a bit, bouncing from 2 psi up to 10 psi and everywhere in between.
So, you guys think its the obvious - the lift pump? A couple hours after I got it home I turned the Quad box all the way up (100 h.p.) a did a couple full throttle runs and she didn't skip a beat. Not sure what to make of everything.
This time while cruising home on the freeway. Here's what went on:Cruising at about 75 mph with the Quad X2 on the Mileage Max program I could feel the truck slowly picking up speed. So I lift just a hair and it slows too much, so I feather in a little more throttle and again it picks up too much speed. Again I let off just a touch, and again the truck slows too much. So I add a little throttle, then a little more, then even more but the truck continues to slow. I quickly more to the shoulder and before I make it the truck dies. I immediately check for codes and get nothing! So I start her back up, she fires right away, and I drive home without further incident. But I did notice my lift pressures where jumping around quite a bit, bouncing from 2 psi up to 10 psi and everywhere in between.
She did it again!
Could it be the TPS?? My wifes 03 floored its self while she was parking one day scared the crap out of her luckily she didnt hit anything. It has never happened again just a thought.
You know I had a similar problem, but I was going down the road and the cruise engaged it self. I was going 40-45 and all of a sudden I'm being sucked back into the seat. I tried to brake, but it just kept going, the only thing that stopped it was pushing in the clutch.
The brake didnt stop my wifes either luckily she had the presence of mind to kill it since the brake didnt shut it down I just assumed it was the TPS being a squirrell probably will never know.
Cruising home after my son's soccer game I see this guy in a lowered and hopped-up HEMI powered quad cab eye balling me while stopped in the cross traffic. So as I turn the corner in front of him I figure I'll lay into it a little and let him hear the turbo sing a bit and follow it up with a chorus of screaching tire
. So I roll into it pretty good as I make the turn and the turbo starts singing and right when I think its about to light off the truck falls flat on its face and the engine dies!
What the heck? Fuel pressure seemed normal, although I was watching the road and not the gauge when it died, and the CEL did not come on. Not sure if there are any codes stored because I forgot to check when I got home. Fuel filter is pretty fresh with only 2500 miles or so on it, and I have about 1/2 tank of diesel. Think the lift pump hiccupped? Or may be on its way out? I got on it a couple times afterward and it seemed fine.
So what do you guys think?
. So I roll into it pretty good as I make the turn and the turbo starts singing and right when I think its about to light off the truck falls flat on its face and the engine dies! What the heck? Fuel pressure seemed normal, although I was watching the road and not the gauge when it died, and the CEL did not come on. Not sure if there are any codes stored because I forgot to check when I got home. Fuel filter is pretty fresh with only 2500 miles or so on it, and I have about 1/2 tank of diesel. Think the lift pump hiccupped? Or may be on its way out? I got on it a couple times afterward and it seemed fine.
Think I found the problem.....
Found a seriously frayed wire on the Quadzilla harness while installing the new X2 harness. I most likely cause the damage while pulling the harness through the firewall
. I was very careful with the new one so as not to end up with the same issue.
