my own 2 cycle experience
Old Jul 30, 2007 | 11:57 AM
j's Avatar
j
not looking to start another battle over addatives, just giving my own experience. lately i have been driving to the coast alot, using the same route and same speed (70). this last week a read a thread about using 2 cycle tcw-3 in the fuel. it takes a full tank to get there and back and while i was there, i drove the exact same route to breakfast, etc. in the previous weeks my calculated avg mpg was 16.5 mpg. this last week, with the only difference being 2oz of 2 cycle per gallon of fuel, i avg'd 19.4 mpg. could be a fluke, could be actual. the truck computer showed 16.1 on previous trips and 19.1 on this trip so there is some improvement even if only minor... on this last trip the truck was 117 lbs heavier (wife and 10 month old).
the was no difference in sound that i could hear, just my $.02..
Old Jul 30, 2007 | 12:02 PM
txfiremedic's Avatar
Thats an impressive gain!!! I would try the same trip again w/o the oil and then again with it and see if you get the same results again. Great info!!
Old Jul 30, 2007 | 12:12 PM
j's Avatar
j
i'm going to try different things too. they say putting the tailgate down doesnt effect mileage, but on my 04 ford it improved 3 mpg and you could actually feel the difference in drag at speeds above 50, so ill try that too.
Old Jul 31, 2007 | 12:13 AM
duallydave's Avatar
we need a scientist dude on this one,maybe 2 cycle oil has a high btu rating.maybe theres cetaine in it also.
Old Jul 31, 2007 | 06:12 AM
coolslice's Avatar
I don't think there's any logical way oil could improve mileage that much. I know that it hasn't done anything special for mine. There are so many factors that go into MPG that I really don't understand how people can pinpoint one exact thing as the deciding factor.
With all the buzz about 2 cycle oil, I have been doing my own testing with hand calculations and all and I have not experienced any of the benefits others claim. If anything my mileage may have gone down a bit. If my engine is quieter it's not enough for me to notice by ear.
Old Jul 31, 2007 | 07:38 AM
Totallyrad's Avatar
If you can consistently average a 3 mpg increase you can come out ahead, even using that much oil. The problem most folks have when using additives is when you factor in the cost of the additives vs the actual gain in mpg, you lose money. Keep up with your results and hand calculate if you would as most folks just look the other way when you mention the overhead. I think the last two stroke I bought from Walmart was just under $7.50/gal out the door. On the plus side, the extra lubrication is hard to beat.
Old Jul 31, 2007 | 10:20 AM
Rollin' Smoke's Avatar
i really dont think people are using the 2 stroke so much for extra mpg's as they are for the extra lubrication it provides the fuel system with. since the swap over LSD to ULSD.
Old Jul 31, 2007 | 04:54 PM
j's Avatar
j
I did the hand calculation as well which i explained above. could be a fluke also. there was wind in the same direction on both tests and approx the same speed. it could be air temp which was a couple degrees cooler on the 2nd test... this post wasnt meant to spark a debate, just offering my own experience. i mainly added the 2 cycle as a lubricant. this morning i filled up again and added the oil after i got home. the truck was running and after a few minutes it did seem quieter, but only slightly. i'll keep checking how it all works out and update the post periodically.
Old Jul 31, 2007 | 05:02 PM
Totallyrad's Avatar
I'm not trying to debate with you. I want to hear about anything that increases mileage. I can always stand more of that, it's just important to keep as many variables out of the equation as possible. That makes the results easier to understand and reproduce. Sometimes it's the little things that make the difference.
Old Jul 31, 2007 | 05:14 PM
danc46's Avatar
I tried the 2-stroke oil vs the 50/50 mix of Power Service and MMO on the same road going in two different directions. Approximately 300 miles one way. No residue of my usual PS/MMO was in the tank on the return, just the 2 stroke oil.
I lost almost 1 mpg using Walmart 2 stroke oil.
The vehicle had just at 10,000 miles on the odometer.
Old Jul 31, 2007 | 08:50 PM
Nitro71455's Avatar
Head wind the first trip and tail wind the last????? That's about the only way I could see getting an increase of that much.
cbtumedic
Nov 4, 2007 04:06 PM
srt20
Apr 18, 2007 10:05 PM
Jambbii
Oct 2, 2006 12:37 PM
Mexstan
Mar 31, 2003 11:25 AM
adgr71
Jan 26, 2003 09:25 AM
