My new engine doesnt smoke?
Old Apr 17, 2009 | 02:51 PM
sallyman1's Avatar
my new engine and bosch stix dont smoke black at all. even if i roll into it ,up hill and floor it nothing. clear as can be. my old engine blew tons of black stock. my hypothesis is that if you have a HPCR and it blows black stock, that is a sign of injector wear. not saying you need new stix right aways but sometime in the near future. I think higher pressures and bad filtration(ULSD etc..) are what cause premature injector wear and will continue to be a problem in the future. what do u all figure?
Old Apr 17, 2009 | 03:27 PM
cody459's Avatar
I agree with higher pressure it cause the tips on the injectors to leak and crack. As for the filtration every diesel mechanic i've spoke with agrees the
2M system is the only way to go. As for my re-build i've put 15k miles on it and still no black smoke and very clean oil.
Old Apr 17, 2009 | 04:25 PM
sallyman1's Avatar
you got a rebuild as well? i did to and mine is clean. im getting a fass installed next week and ill run 2 micron in the summer. in winter ill have to switch to 3 or 5 i believe or else i might wreck the fass im thinking due to our harsh winters
Old Apr 17, 2009 | 04:50 PM
cody459's Avatar
Yeah, I had to re-build mine at 120k and replaced all six injectors and turbo.
Old Apr 17, 2009 | 05:22 PM
sallyman1's Avatar
wow. my turbo was ok. all i noticed so far other than no smoke is i cant seem to build over 30lbs boost with this engine. thats also empty and obviously its not broken in yet. i only have 900 km on new rebuild.
Old Apr 17, 2009 | 06:01 PM
cody459's Avatar
The boost will get better over time, it usually takes about 5000 miles to break a re-build in.
p.o.s.
Jul 14, 2009 10:32 PM
cmed250f
Nov 6, 2007 12:28 AM
mytrucksaslug
Sep 14, 2006 06:38 AM
502502
26
Oct 1, 2005 09:32 PM
Timmay2
15
May 17, 2005 05:09 PM
