My Mag-Hytech tranny pan LEAKS!
I put a Mag pan on my 97 with the included rubber "reusable" gasket, it leaked.
Now, on my 2006, I put a Mag double deep on and it leaks too. (They sent it with the cork gasket).
Do you think I could use the OEM ribbed rubber looking gasket on the Mag pan? Or will it leak worse?
cyclone??????? Do you mean silicone? Don't use that just put the stock tranny pan gasket back on. It can be reused several times before needing replacement. You don't want anything getting loose from the pan gasket and getting into the tranny.....
Are you sure you are not referring to your rear Diff Cover?
On my MH DD Trans pan, I have used both the Cork and then later the Rubber reuseable gaskets and didn't have a problem with either one leaking.
When I did a trans fluid change (stock pan) I used the supplied gasket that came with the filter. It leaks. I retained the original gasket and will definitely use it when I add my deep pan.
Nope. Definitely the DD trans pan. Just put it on a couple weeks ago so maybe a new feature? Got it from Geno's
Country23047
Jul 13, 2008 09:41 AM
6cylinders
Dec 4, 2003 11:02 AM
