Mobil 1 Synthetic in the Six Speed & Rear?
From: Dead Center in the Middle of TN. 20 miles from Jack Daniels, 10 miles from George Dickle and .8 mi from the liquor store at I-24 Exit 114
Mobil 1 Synthetic Extended 5w30 motor oil in the Six Speed ? I have 11K on the Ram and it is time to change it over to Synthetics
Mobil 1 Synthetic Gear Lube in differential?
I need something readily available and Mobil 1 is what oil I am going to use when I change the Cummins to Synthetic Oil.
Mobil 1 Gear Lube in the rear end is fine.
But for the 6sp, you need to run Redline MTL for it, or Pennzoil Synchomesh for the trans.
5w/30 is the close to the viscosity, but it doesn't have the extra stuff that is needed for the trans.
Does Mobile 1 have anything that is compatible for the 6 speed?
If not is Pennzoil Synchomesh Synthetic? What weight of synchromesh if there is more than one?
BTW Thanks jim
BTW Thanks jim
BTW Thanks jim
BTW Thanks jim
I just did a change of both diffs, tranny, and transfer case this week. I used the factory fill for the tranny, and transfer case, and Mobil 1 75W-90 in both diffs.
Go over and read this thread. You have to use a GL4 rated transmission oil in the NV5600, not a GL-4/GL-5 rear end gear oil. And, Motor oil doesn't cut it either.
https://www.dieseltruckresource.com/...threadid=61850
BTW, The transfer case uses Mopar ATF+4 fluid. I believe the Redline C+ and the Amsoil ATF both meet the specs.
Pennzoil/Quakerstate (same company) Synchromesh and Redline MTL all meet the specs. Royal Purple Snchromax does NOT!
Just ordered 4 quarts of Mobil 1 75W-90 and five of the Penzoil Synchromesh. AutoZone will have them waiting for me this afternoon.
I will also pick up a 17mm allen socket from Sears just to have on hand.
Thanks for the info guys! jim
Capacities:
Rear diff. 7.65 pints
Front diff. 4.75 pints
NV5600 9.5 pints
Torque specs:
Differential cover bolts 30 ft/lb
Differential fill plug 24 ft/lb
I am not sure on the torque specs for the tranny. I haven't done mine yet. Hopefully someone else will post those specs for you. The important thing is to be careful on the differential cover bolts. I have heard of quite a few being broken if you don't use a torque wrench.
Thanks for the help guys, It's nice to have all of this info and assistance readily available.
Jonesey If I only had an Axel in front that needed it I would buy some more to go in it. Mine is just a lowly 2x2 single Axel truck. I have Jeeps and really want an asphalt only truck.
I hope these fluid changes will make it shift better and secure the level in the rear that I have been concerned about of late. This and a fuel filter will do me until the next service due at 15K, that is when I get to put in the Mobile 1 SUV Synthetic Oil. Thanks, Jim
runamuk
Apr 6, 2006 11:24 PM
dodge 3
May 3, 2005 04:54 PM
PITBULL
Jan 20, 2005 09:18 PM
Diesel Dave
Apr 2, 2004 05:34 AM
