Mobil 1 ATF
Old Sep 25, 2008 | 07:50 PM
jjoiner's Avatar
Question Mobil 1 ATF
Is there a problem with running this oil in a 48re? I know to use a synthetic fluid which this is but was just curious. There doesn't seem to be much talk about it in the forums. Thanks for any help.
Old Sep 25, 2008 | 11:59 PM
06RAM2500's Avatar
As long as it's compatible w/ ATF+4 or has the same friction modifiers.
Old Sep 26, 2008 | 08:31 AM
Sniper05's Avatar
I don't think mobile-1 syntec is compatible with chrysler ATF+4, If you are going to buy it at a local parts store or something like that, i am pretty sure castrol syntec is compatible!
Old Sep 26, 2008 | 09:54 AM
SundayMoney's Avatar
When I changed out the factory fluid about 9 months ago,Mobil 1 wasn't approved.
Although I didn't want to,I used Amsoil instead.
Not that Amsoil is bad,I've just never had the results I expected after listening to all the hype.
Old Sep 26, 2008 | 02:17 PM
DBLR's Avatar
The info I have read on the Mobil 1 web site is they recommend Mobil 1 ATF for Dodge trans but no where does it say there ATF meets or exceeds Mopar ATF+4 specs. So I would not use it, that an Mopar ATF is made from group III crude oil base stock, its not synthetic, its just highly refined Dino oil. If you want 100% group IV or V man made synthetic ATF then buy either Redline or Amsoil.
Old Sep 26, 2008 | 04:37 PM
COUNTRYBOY's Avatar
I put Lucas Simi syn in my 518 and it's running pulling and hitting passing gear alot easier and and seems to hold harder, so far I really like it...
Old Sep 26, 2008 | 06:57 PM
D45's Avatar
D45
Do not run Mobil 1 ATF in your truck!
Old Sep 26, 2008 | 07:37 PM
jjoiner's Avatar
Thanks for the info. everyone! That narrows it down to two locally avail. fluids; Valvoline syn. or Mopar(@ Wal-Mart). Any preferences?
Old Sep 26, 2008 | 09:22 PM
Hounddog's Avatar
What did you expect from the Amsoil Atf.? Found that a interesting statement..Just curious.
Old Sep 26, 2008 | 10:03 PM
I'm assuming your refering to me.
I don't like the notchy feel of my G56. I read post after post about improved shift quality with Amsoil. Drained the factory fill and replaced with Amsoil and if there is a difference I can't feel it.
I also ran Amsoil in my '98 Z-71. I ran a few used oil analysis with the Amsoil and wasn't overly impressed with the results.
A lot of guys swear by it,but IMO its overhyped and overrated.
Old Sep 27, 2008 | 03:39 AM
Hounddog's Avatar
Its a top tier lube.Amsoil and a few others are the best of the best.I don't notice or very little differance in Chevron or some other name brand top tier fuels over the no name couple a cent per gallon fuel eaither.But over the long haul their is a differance.I understand about the trans feel.Some things are just the way they are.
Old Sep 27, 2008 | 04:51 AM
jjoiner's Avatar
Bump......
Old Sep 29, 2008 | 08:37 AM
DBLR's Avatar
Of the 2 you list buy the one that is the cheapest as both are more or less the same.
Old Oct 2, 2008 | 04:48 PM
Boss Hoss 540's Avatar
Been running the Amsoil since 15k in mine (91k now) with no issues but I did flush it all out of the converter when I did it. Changed it at 78k and it was almost the exact same color as the new stuff.
Old Oct 2, 2008 | 04:50 PM
I did but I changed it ALL out not just a drain.....also put the big ATS pan on.
