Missing/ white smoke????
Old Oct 20, 2008 | 01:25 PM
Rtikul8's Avatar
Ok, I have had the truck miss a couple of times, both at light throttle, and it puffs a cloud of white smoke when this happens. Took the chip off, and also put in a new fuel filter as well, and it has happend again. Any ideas?? Injectors? Cp3?
Old Oct 20, 2008 | 01:36 PM
Texasimport's Avatar
Change the fuel filter if not done recently. Then run some injector cleaner through it. If your white smoke, rough idle stays I might get a leak check done on your injectors.
Old Oct 20, 2008 | 02:03 PM
Rtikul8's Avatar
Thanks, I will get some cleaner asap! It idles just fine, drives fine, no smoke at startup, only when it misses. Almost like it runs out of fuel for a split second.
epenn03
Apr 7, 2008 07:27 PM
Prowler1973
Sep 12, 2007 08:39 PM
Captain
Feb 3, 2007 07:39 PM
Jenubi
Nov 23, 2004 03:45 PM
