Is that metal coolant line behind the motor covered under motor warranty?
Seems like it would be a cummins part maybe
. Dang thing is leaking from a welded joint it seems. Good thing I caught it leaving the deer lease had to jump someone off and noticed. Got a steady drip.
Radiator was full and the reserve was a tad low. Made it back to Houston ok.
. Dang thing is leaking from a welded joint it seems. Good thing I caught it leaving the deer lease had to jump someone off and noticed. Got a steady drip. Radiator was full and the reserve was a tad low. Made it back to Houston ok.
Talking about the metal line that runs between the block and turbocharger? If so check the short rubber hose by the turbo for leaks. May want to replace the cheap clamps with some good stainless hose clamps.
MikeyB
MikeyB
It runs from the right side of the heater core then splits off. I'm pretty sure it's leaking from the split where it is welded and Y's off.
If it's not covered I'm gonna rough it up and put something like JB weld there. Wish I could solder it but it's on the bottom where it's leaking and it looks like an SOB to get off.
Take a look at this thread, post number 2, and see if that's your problem.
https://www.dieseltruckresource.com/...e-t249595.html
Well I tried to replace that hose last week and have no clue how to get it off so I just tightened the existing clamps and it quit leaking. I put the new hose/clamps in the glovebox.
JIT
Jan 9, 2006 05:59 PM
Tommy93w350
Jun 20, 2005 04:51 PM
Bowman
Mar 19, 2005 01:07 PM
030303
Dec 1, 2004 06:58 PM
chrismez
Nov 8, 2004 06:38 AM
