Messy oil change
Messy oil change
Man i just changed my oil for the 4th time and this one was the messiest yet! The problem was when i removed the oil filter it started running all down my arm and all over the frame which it has never done before when just loosening the filter. I did all this about 15 minutes after shutting down the truck.
I am guessing i should have waited longer to remove the oil filter to let more oil drain down into the pan or soak into the filter more?
A big zip loc bag works good too. In a tight Ill use a couple wally world bags inside each other, and that works just as good.
When you say you loosen the filter and let it drain, that is what i did but when is the first time oil has came out from top the filter.
Do you let drain out the top of the filter or are you refering to the drain plug?
plastic bag works the best, get the filter loose enough so u can spin it by hand but tight enough that the oil isnt draining out.... then put the bag under/ around it and then take it completely off so it drips into the bag
It seems to me, that if it sets long enough, no oil comes out of the filter. I can't say how much time is enough though ! I've had it be completely dry, and had it dripping down my arm too! LOL
From: Adirondacks of New York and Daytona Beach FL.
Loosen the filter a little......slip a plastic bag up around it and carefully remove filter.....what spills goes into bag ....not on arm or floor......
you're supposed to change the oil while it's hot!
I take mine for a 10-15 min spin then in to Wallys World and let them change the oil...NO mess!! Just bring your fleetguard filter with you. it costs about $46.00... a real bargain if you ask me.
when your neighbor is at work pull into his yard. unscrew the filter and let it fall. kick it into the storm drain. slap another one on there. pour in new oil. check level. do donut in yard. call police and say some kids were jacking around in neighborhood. you are all done...
dont forget to fake sorrow for neighbor
brett
brett
brett
brett
yall will never guess what i did with the oil. i just got back from my buddies house and he has 4 hogs that i pour it on the tree in their pen. that is how i dispose of all my oil. i will get video next time. wait i think i have some pics...
Thats worse than takin' it to walmart!!
