Mega Cab 2500 or 3500?
Old Aug 22, 2006 | 11:50 AM
ptgarcia's Avatar
Originally Posted by stevestir
I'm reading all the posts and it looks like my new 2006 Mega Cab CTD 2500 4x4 can only tow about 12,000? My Dodge dealer tells me I can tow a 12,400 TT or a 15,700 5'er. Said the hitch on the TT should be no more than 1,200 lbs but did not say what the 5'er hitch max is. I bet my Ram can pull 15,700 specially if I add the exhaust brakes and Edge controller I'm thinking about, but am I legal? Dodge website only says when properly equiped. Whats the max I can tow and the 5'er hitch max for my 2500? By the way, I'm thinking of getting a Forest River Cherokee Wolf Pack TH?
Technically, no, you cannot pull that much 5th wheel. Physically, yeah probably, but you'll be way over rated capacities. A 15,000 lb 5th wheel is really better towed by a 1-ton dually. That's a lot of weight.
Old Aug 22, 2006 | 01:54 PM
jrogers's Avatar
3500 looks cooler than 2500
Old Aug 22, 2006 | 05:26 PM
Turbobob's Avatar
I bought a 3500 SRW Mega. It was only a few hundred more than a 2500. And no, the cab lights are NOT standard on the SRW 3500(at least mine doesn't have them) Same height as the 2500 and as said before, the overloads come into play when they contact the frame pads under heavy loads
Old Aug 22, 2006 | 08:34 PM
kev94mx's Avatar
Thats why I went to a dually was weight issue. My 2500 did very well pulling but here in NC they have cracked down on weight and payloads. I was barely legal with my trailer and hoe. I had timbren rubber springs on my 2500 and the other day I hooked up my trailer and dang it squated my dually almost as bad as my 2500 stock. I wonder what happen to the rear leafs that come on the 2nd generations? I guess I will put the timbrens on my dually.
Old Aug 22, 2006 | 10:49 PM
nghthwk's Avatar
Good deal huh. got mine at the same place exactly the way I wanted
Dean400
May 14, 2011 04:55 PM
jimbo486
13
Nov 5, 2009 09:17 AM
drewallen42
105
Sep 27, 2007 11:28 PM
jrussell
May 8, 2007 09:24 PM
4x4dually
May 11, 2006 10:46 AM
