Measuring ring gear backlash ?
Old Nov 15, 2004 | 02:36 PM
Svenne's Avatar
I'm about to try for the first time. The service manual shows the procedure with the use of a stud ( specifically a slotted set screw ) threaded where the adjuster lock bolt normally goes into differential bearing cap. This seems like a good way to perform so I'd like to acquire a similar stud beforehand. Anybody know the specs on this bolt ? Anybody have experience using a magnetic base for procedure ? Comments.
Sven
Old Nov 15, 2004 | 02:42 PM
nickleinonen's Avatar
mag base works good. just stick it to the housing with the mag base and measure away.. 0.002"-0.012" iirc are the specs you are looking to see [i looked them up in my 03 service manual a few weeks back so i might be a little off].
Mike Holmen
ABDTR #5
Oct 19, 2009 11:13 AM
t_syverson
May 3, 2008 10:04 AM
D.S.
Aug 29, 2006 01:52 AM
RowJ
Nov 23, 2004 11:27 AM
mcevins
Jul 9, 2003 08:16 AM
