MBRP cat test pipe install?
Old Apr 16, 2007 | 01:33 PM
Arkapigdiesel's Avatar
Just to make sure that I'll do this right.....after the exhaust clamps on the front and back side of the cat are loosened and removed, heat has to be applied to where the clamps were at?
How hot? Does the pipe have to turn red all the way around? After the pipe is heated, how long will it take to get the cat and the pipe removed? Will the cat delete install pipe go on easier than the removal? TIA.
Old Apr 16, 2007 | 01:45 PM
t-boe's Avatar
Mine came off without any heat. It wasn't near as tight as the muffler. Install was simple. I used accu seal clamps instead of the U clamps. Make sure the pipe is seated really well BEFORE you clamp it down.
Old Apr 16, 2007 | 02:10 PM
dodgezilla04's Avatar
mine was a pita to remove. have to sawzall, air chisel, beat it, pry it, cuss, bleed, and heat. you name it, i had to use it. GRRRRRRRRRRRRRR
Old Apr 16, 2007 | 03:53 PM
dzilla,
How crimped were the pipes from the U bolts? I loosened the bolts today to inspect the crimps. They were crimped from being tight, but they weren't what I would consider to be excessively crimped.
Old Apr 16, 2007 | 03:57 PM
t-boe's Avatar
Mine were crimped a little. It still took some wrestling, but it came off. I also did this with the truck on the ground. I just wrapped my arms around the cat like I was hugging it and planted my feet to something under the truck (front tire for me) and lifted with my legs. Popped right off. I did have to twist it back and forth a little.
Old Sep 1, 2007 | 03:55 PM
blueyedwolf71's Avatar
Does this cat test pipe make the truck sound any different?
Old Sep 1, 2007 | 04:00 PM
tritont's Avatar
I'm with Zilla.... they were clamped and deformed too tight to even think of working them loose. A sawzall does wonders
Old Sep 1, 2007 | 04:04 PM
Performance's Avatar
Makes it sound a little louder.
I had a hard time with mine. I had to use a cutoff wheel and split the converter pipe (Top & Bottom). Wrestled with this thing for a half hour and finally pulled it off. It's a lot easier to get the delete pipe back in. I actually welded all my seems up, because of a few leaks.
But, it was all worth it! Makes a huge difference in the sound.
Old Sep 1, 2007 | 07:20 PM
07ctd's Avatar
mine came off without any heat. i used alot of loosen it, its just like wd40. i sprayed the heck out of it and wiggled the pipes apart. but when i put the test pipe on i couldnt get it to seal good so i had a muffler shop weld it.
Old Sep 1, 2007 | 07:24 PM
Luvnacumns's Avatar
Mine came off without heat too.. Just an 18v sawzall!!!!
gadget
Sep 1, 2009 01:56 PM
gadget
TXDTR #8
Sep 1, 2009 12:45 PM
Arkapigdiesel
18
Apr 20, 2007 03:01 PM
NVMike
Mar 7, 2007 08:24 AM
