MB G56 6-speed?
Old Aug 21, 2008 | 02:32 PM
Thundercloud's Avatar
Question MB G56 6-speed?
Does anyone know if the G56 6-speed trannys that Dodge has been putting in their trucks since the 05' model year are made by Mercedes Benz? I was just looking at the Sterling Bullet truck website and they advertise that their G56 is made by MB. Just curious.
Old Aug 21, 2008 | 02:34 PM
MikeyB's Avatar
Yep, it is. Believe it's made in a Daimler plant down in Brazil.
MikeyB
Old Aug 21, 2008 | 03:44 PM
MikeyB
Well ya learn something new everyday.
Thanks MikeyB
Old Aug 21, 2008 | 04:09 PM
rbrettctd's Avatar
I had heard once it was a Getrag design made through MB, is that correct or not?
Old Aug 21, 2008 | 04:54 PM
DaveB.inVa's Avatar
As far as I know its straight MB, no Getrag in it at all.
I think a LOT of the whole Getrag confusion comes from the "G" in G56. I've met more people than you can imagine that thinks its a Getrag.
Come to think of it I've met plenty of people that believe Ford owns Cummins (or Cummings), the Duramax is built by International... etc.
Old Aug 21, 2008 | 08:38 PM
07dodge's Avatar
Its a getrag
Old Aug 21, 2008 | 10:05 PM
XLR8R's Avatar
No, it isn't a Getrag.... at least not since Ford sold CumminGs.
MB has been mass producing the G56 down in Brazil at least the last several years for medium duty trucks.
Old Aug 21, 2008 | 10:31 PM
PRO-NRA's Avatar
Originally Posted by 07dodge
Its a getrag
As few people already mentioned, it is definitely not a Getrag. It is manufactured in Brazil by MB for medium duty trucks.
Old Aug 21, 2008 | 11:51 PM
no_6_oh_no's Avatar
Considering MB builds vehicles and not transmissions that statement not be completely true. Getrag builds a lot of transmissions for MB and at one time did build the G56 plus supplies components for it. Probably still builds the units for certain applications in Europe.
The G56 has always been considered an MB design but if you dig a little deeper into the relationships you will find that Getrag has a long standing design and production relationship with MB. It a pretty good assumption Getrag had more than a peripheral hand in the design process. They have the expertise after all.
The current facility in Brazil is a cooperative effort between several international transmission and component builders with investments from Daimler AG and others. Since the prodcution rate is much higher and the costs cheaper it only made sense to source as many of the units from the Brazilian plant as possible.
Soo, is it a Getrag or is it not a Getrag? Not so cut and dried answer, and, for the most part a moot point. Unless we run out of OTHER arguing points.
Old Aug 22, 2008 | 07:51 PM
NickBeek's Avatar
Tastes great....Less Filling.....Tastes Great! For those of you old enough to remember.
Old Aug 23, 2008 | 02:56 PM
smokey196240's Avatar
I remember, plus as long as it works as good as it does im happy
Old Aug 23, 2008 | 03:37 PM
UnrulyNFS's Avatar
Not for high horsepower applications as I discovered.
Has a MB badge on the side.
Old Aug 26, 2008 | 02:19 PM
nelrod's Avatar
Unruly, how much HP/TQ do you think it can handle. No drag racing or sledpulling, just pulling and playing around a little.
Old Aug 26, 2008 | 09:38 PM
XLR8R's Avatar
Nelson, I know Keegan can tell you how much HP/torque his G56 couldn't handle!
Old Aug 27, 2008 | 02:03 PM
Tacsavage's Avatar
I would guess once you get around 550hp to 600hp if you behave, you are bordering on the edge of destruction. Keegan went from 571hp to into the mid to upper 600hp range and it lasted only weeks. I know of several other guys who have had multiple failures and they are over the 600hp range as well. Have seen posts where stock trucks had them fail. Seems like a lot of people loose 3 or 4th gears.
