Massive fluid change this weekend
Old Jul 1, 2008 | 05:49 PM
_Adam_'s Avatar
Originally Posted by Desert Dually
How many quarts do i need for '07 3500? Any brand considerations? I dont need a new gasket, do I?
I read 4 quarts in the manual, but I could be wrong. With the Oasis diff cover I installed, I needed 6 qts.
Old Jul 2, 2008 | 10:56 AM
DBLR's Avatar
No need to use any RTV sealant as the gasket are reusable. When I changed mine out it took 3 qt for the front diff and 4 for the read diff. I used Amsoil 75/90 severe gear oil as its good for 50K under sever usage and 100K for normal usage. What every brand of gear oil you use check your diff's every 10K so that you know how well your gear oil is holding up and that its GL-5 rated synthetic gear oil. Oh if the gear oil you want to use is not synthetic don't use it as your diffs require synthetic GL-5 gear oil. Also take the covers off your diff so that you can drain out all of the factory junk oil and also so you can see if your gears are burnt or not and to clean any metal build up in the bottom of the diff.
markm4
Jul 29, 2007 11:16 AM
B.Law
Feb 6, 2005 12:48 AM
SilverDodge
48
Aug 21, 2004 11:19 PM
BEHRMAN
26
Feb 8, 2004 11:49 AM
timdewaltman
May 26, 2003 11:22 PM
