Massive Defueling ...... HELP!!!
Old Aug 14, 2004 | 07:01 PM
SilverDodge's Avatar
I am trying to get the last of the bugs worked out after doing my 6 speed to auto swap. I am having massive defuel at 2000 rpm. If i powerbrake it, it will rev to 2k in a hurry blowing lots of smoke, then as it crosses 2k, its like someone throws a switch and the power and smoke is gone. It WILL NOT break the tires loose from a stop under any circumstance! If i try to launch just before hitting 2k it will accelerate to 2100, cut power, rev to 2300, cut power, rev to 2500, cut power all the way up to 2900, then pull strong to 3100ish. Any ideas at all on what i can do???
Thanks
- D
Old Aug 14, 2004 | 07:39 PM
psalm69's Avatar
Is the torque mgmt system on the 6ers the same as on the autos? Maybe its pulling power for that reason. Scott
Old Aug 14, 2004 | 07:52 PM
when we did the swap we changed the ecm and pcm from the then auto truck to mine. (i found an identical truck to mine that wanted a 6 speed and went to town)
Old Aug 15, 2004 | 10:02 AM
OPIE's Avatar
Re: Massive Defueling ...... HELP!!!
Thanks
- D
Are you throwing any codes?
I would diagnose with a scanner SD if I were you.
Also if you able to power brake to 2k rpm's and not break the tires loose your going to be hating your 60' times. Anything above 1200 rpm's and my truck is painting black lines.
Opie
Old Aug 15, 2004 | 11:41 PM
Re: Re: Massive Defueling ...... HELP!!!
Opie
I am going to go to dodge tomorrow and hook up the odbIII. do you think i could benifit from a software reflash?
you are running stock (or close to) tire size right? I am assuming that is going to take a few more r's to get my 37's going. are you breaking loose without boost? I can only build a few pounds before it smacks me down. I also am not running anything big for injectors at the moment.... just supermentals
- D
Old Aug 16, 2004 | 12:51 AM
BTW Opie... i was actually up in your hood today. Went partying in seattle last night and caught a mariners game today. Lots of fun!
Old Aug 16, 2004 | 08:09 AM
OPIE's Avatar
SD
Did you swap injector pumps when you transfered over too? Whether you reflash or not you still need to see what codes are set. In the past there have been others that haven't liked the reflash.
I am only running 305/70/16 tires but if you would like we can put your 37's on the back and I can show you my point. lol
Old Aug 16, 2004 | 12:14 PM
opie
i didnt swap pumps because i have a race pump. Didnt feel like giving that to him!!! I am out the door to go to dodge.... curious as to what codes i might have. ill let you know when i find out
- D
Old Aug 16, 2004 | 12:17 PM
Don M's Avatar
DTR Advertiser
The 37" tires will hurt performance. On the dyno and the sttreet.
Don~
Old Aug 16, 2004 | 12:37 PM
CDRAM's Avatar
I noticed a 25 h.p. loss when I put on 36" swamps with 3:55 gears, also if you do some digging around in posts, you will find that most of the most violent de-fueling issues, come from people with highly modified trucks running oversize tires. I'm going to see if these problems are going to be fixed by marco with new ecm. SD when you go to dealer today, have the tech plug in the drbIII, go into the abs mode, he will see two preset tire size values 265 and 285, then below that he will see other, go into that screen and it will say blank rev's per mile, you need to call les schwab to find out that rev per mile for the 37. its 599 for 35" Hope this helps
Old Aug 16, 2004 | 07:39 PM
CDRAM - i have the superlift speedo recalibrator. wouldnt that do the same thing?
Old Aug 17, 2004 | 08:44 AM
OPIE's Avatar
opie
- D
Well I guess that rules the pump out, did you set any codes?
Old Aug 17, 2004 | 10:04 AM
my buddy wasnt there yesterday.... so i will have to wait till thursday to go do it. This is getting very frustrating!!!
Old Aug 17, 2004 | 11:32 AM
CDRAM's Avatar
The true speed would do the same thing if all is well, i didn't know you had one of those.
Old Aug 17, 2004 | 12:19 PM
Don M's Avatar
DTR Advertiser
SD,
Buy a RAD box from BD Power! Until you do, it will always defuel.
Don~
