manual vs. automatic
Old May 12, 2008 | 08:54 AM
Grit Dog's Avatar
Originally Posted by snoyes
Well, can't talk to the other, but for the 06 G-56, the six speed manual probably gets a little worse mileage on the highway because of the gearing. The 07 has better gearing for the G-56 and will do much better on the highway.
What is the OD ratio on the 06 vs 07?
What rpms are you guys seeing on the 07 6sp, 3.73, 265 tires at 75, 80, 85mph?
Sorry, just bought the truck, didn't get over 65mph test drive, wife is bringing it up from Denver today (It's her new truck anyway. I think I win for best Mother's day gift!
Old May 12, 2008 | 11:08 AM
RobG's Avatar
Wow sure wish I got in the high teens and 20's like you guys.
My 05 G56 is great... definitely a bit short in the top gear but it works so very well in everything else that I don't complain much.
I went to Reno and back this weekend... on the way there, I ran 70-75 and averaged 15.3 mpg. On the way back, I ran 62-65 and got 18.2 mpg.
That's with Smarty on #1 (Revo). I can't run anything higher until I finish breaking in my new clutch...
Rob
Old May 12, 2008 | 12:02 PM
AH64ID's Avatar
05-06 G56 is .79 OD (Same rpms in 6th with 3.73's as a NV5600 with 4.10's)
07+ G56 is .74
NV5600 is .73
I have a NV5600 and dad has a 06 G56, the mileage difference cruising is negligible... He does much better towing heavy weight thru the mountians in 6th... Makes me want to add an overdrive, GV or US (.78 or .80)...
I still think the manual tranny is better for every appication but city driving... You have more gears, and more gears where you need them... especially if you tow/drive in the mountains... Even a 6 speed manual is much better than a 5 speed manual for mountain towing... True I would like a lower OD every now and then, but 3rd and 4th are used much more than a lower 6th would be... Look at it this way, (tq converter aside) from 1600-2500 rpms with 3rd and 4th in a 6 speed man gets you 19-44 mph, good power and not screaming the revs... a 5 speed (3rd gear) gets you 23-37, a 48RE gets you 27-42, and the 68RFE gets you 21-43 (better)
As you can see the 6 speed manual has the best range of speed in that gear area and rpm area (data is 3.73 and 265/70/17's).... \
I say go manual... best ratios and you dont have to worry about heat.
Old May 12, 2008 | 01:32 PM
snoyes's Avatar
Agree, I wouldn't have anything but the manual for towing, but for purely fuel economy and ease of city driving the auto may be better. That being said, I've been happy with my G-56. Really works good with the exhaust brake and for when I tow in the mountains....
Old May 12, 2008 | 10:13 PM
SundayMoney's Avatar
Yep, they changed the gearing in the G-56 in the 07. At 65 MPH, I'm at about 2000 RPM in the 06 (with the stock tires). I am getting an average of 15 MPG in this truck, with the stock set-up the best I got 1 tank was a little over 18. Wish I had the gearing in the 07s...
What about the gearing of the '07s do you think is better?
I have an '07 with 3.73s and at 65 I'm turning 2100 rpm. Thats with a 150 rpm reduction when I went to taller tires.
2250 with stock tires sucks.
Old May 12, 2008 | 10:26 PM
AH64ID's Avatar
You have an early 07, somewhere near the 07.5 mark the G56 got a .74 OD vs your .79...
Old May 12, 2008 | 10:27 PM
snoyes's Avatar
You should have lower RPMs than that with the 07 G-56 gearing, unless they didn't switch the gearing until the 07.5 year? .79 for the 06 G-56, .74 for the 07. 2250 RPMs at 65 MPH seems high, what is 2000 RPM for you?
Old May 12, 2008 | 10:32 PM
2000 rpm is right at 60 mph.
Old May 12, 2008 | 10:35 PM
snoyes's Avatar
I see, it was the 07.5 that they made the change.
Old May 12, 2008 | 10:39 PM
AH64ID's Avatar
Well close, as there are some 5.9's with the .74...
Old May 12, 2008 | 10:41 PM
carl48's Avatar
i tow heavy and like the .79 g56 best , i have a hard time understanding why anyone with a Cummings would want a piece of weak expensive junk auto behind it.
Old May 12, 2008 | 10:45 PM
snoyes's Avatar
Another "cummings" reference. The auto can be made to handle some serious power, depending on how deep your pockets are. I think the guys with the new 6 speed auto are fairly pleased, but time will tell.
Old May 12, 2008 | 11:32 PM
RAMRODD's Avatar
Originally Posted by NickBeek
That can be argued. The G56 is geared a little too low for good mileage at higher speeds, but my truck gets excellent mileage (19-20mpg)at or below 65. These trucks were designed to work hard, and if you tow 9000+ lbs that gearing is excellent. .
I pull a lot hevier then most The gearing of the G56 is geat if you live where the speed limit is 55. But time is money and when I am hauling I needed something that can move down the road. I am tagged for 42K and am usually loaded around 39K I went to the 22.5's for the gearing change and that is the best thing I have ever done. Nothing like 80 at 2100RPM
When it comes to auto vrs manual the new 6 speed I don't here much for complaints. But if you are one to tow heavy, past the factory ratings I would stick with a manual.
Old May 12, 2008 | 11:52 PM
caleb_s's Avatar
I would say manual. I love my 05 g56, very strong and I get very good fuel mileage. I have not been able to drive the new 68RFE, but I have heard it is awesome and I am sure Dodge is really getting better with Auto tranny's.
Old May 13, 2008 | 10:29 AM
Grit Dog's Avatar
Well, I lucked out w/the .74 gearing. Took the truck for my first drive last night. Stock 265 tires. At 75mph, I'm at about 2250 rpms, at 80mph, 2350-2400rpms. Not bad. 285's will bring that down nicely!
CACalomino
16
May 18, 2005 09:27 PM
Palmetto_kid
Jun 28, 2004 07:14 AM
antknee
Aug 4, 2003 10:10 PM
azjeff
Jun 24, 2003 07:19 PM
engcogod
16
Oct 29, 2002 07:28 PM
