Maintenance questions
Old Jul 28, 2020 | 07:41 PM
petere1144's Avatar
Hey all, I just bought a 2006 3500 cummins. Its twin turbocharged, fass fuel system, all the supporting modifications, the whole 9. Basically my questions are(as a first time diesel owner) is there anything I should know maintenance wise? I always changed my hemi's oil and did most routine maintenance myself and was hoping to do this myself too. Any recommendations for oil and filters to use? How often should I change the fuel filters, and anything else i should routinely check/change?
Old Jul 29, 2020 | 09:13 AM
FMB's Avatar
FMB
As for changing your oil, many have installed a drain valve in place of the drain plug to make draining easier and MUCH cleaner. I have this drain valve, and this nipple. I put a rubber plug over the nipple after draining the oil and closing the valve as this keeps road dirt out of the nipple (I send a sample to a lab to see how my oil and engine is doing, need a clean sample).
As for which oil, 20 people will have their "Best" oil. I've used Delo and Royal Purple. Lab results don't show much of a difference. I don't remember the frequency of changes for oil and fuel filters on my '03, so can't help you there. Geno's has filter packages at a good price.
Back to morning brew . . .
Crallscars
Oct 31, 2022 10:12 AM
dcwelder
Oct 14, 2007 11:12 AM
cowboy717
May 16, 2006 08:45 AM
PADZZ
Nov 9, 2002 05:14 PM
Fishin2Deep4U
16
Oct 17, 2002 09:19 PM
