Lubricating the Front Drive Shaft
Old Jul 13, 2005 | 08:58 PM
burlhall's Avatar
Question Lubricating the Front Drive Shaft
There is a sticker on my truck by the radiator that says to lubricate the front drive shaft each time the oil is changed. I have looked several times for grease fittings on the u joints of the front drive shaft and can't find any. Anyone know where the grease fittings are?
Old Jul 13, 2005 | 09:43 PM
DR3500's Avatar
there aren't any, I think they are talking about the slip splines in the middle.
Old Jul 14, 2005 | 05:00 PM
J BODY's Avatar
There is a fitting up in the cardigan joint on the front shaft. You need a needle fitting for your grease gun to access and will most likely have to rotate the shaft to find it. Pain in the rear.
Old Jul 14, 2005 | 06:18 PM
burlhall's Avatar
J Body, sorry for my ignorance, but what is the "cardigan joint"?
Old Jul 14, 2005 | 06:26 PM
burlhall's Avatar
DR3500, to lubricate the spline in the middle, one end of the drive shaft would have to be dropped and the rubber seal removed that covers the spline, right? I hope I don't have to do that every oil change.
Old Jul 14, 2005 | 08:11 PM
DR3500's Avatar
J body is probably right, I'm not sure. A cardan joint has 2 normal u-joints and a ball and socket between them to keep it centered. the cardan joint is at the transfercase.
Old Jul 15, 2005 | 12:08 AM
J BODY's Avatar
DR3500 nailed it. It's the double looking universal on the shaft closest to the transfer case. You'll see a small 1/8" silver disc with a little ball in the middle. This ball gets pushed in by the needle grease gun fitting so you can lube the joint.
Old Jul 15, 2005 | 04:31 PM
burlhall's Avatar
Thanks J Body and DR3500. I'm off to get a needle fitting.
Old Jul 15, 2005 | 09:20 PM
Jmac's Avatar
I spent an hour looking for this 1/8" silver disc with a ball in the middle. Couldn't find it.
Can anyone draw me a picture with directions or mabey a photo would help
How about a specifics on where to find this little guy.
thanks
Jamie
Old Jul 15, 2005 | 09:23 PM
TAS05CTD610's Avatar
Sometimes you can call it's name, here zerky zerky. In all honisty it is very hard to find. I'll try to snap a picture of it if I have time (packing for a week trip in VA) but I'll try to get a picture. Also mind you in my picture the paint is scraped off. I really do think they paint over it factory. Best bet is to get under the truck with a flash light and look at the 2nd u joint away from the Transfer case (it'll be the middle u joint) Put your head in front of the transfer case skid (twards the front of the truck) and look for it. You can jack up one wheel so you can turn the drive shaft. It's in there in the center of the u joint. It's very hard to find but you'll get it.
Old Jul 15, 2005 | 09:27 PM
Jmac's Avatar
VVVEEEEERRRRRRYYYYYY funny, tried that it didn't work and the neighbors thought I was looking for a dog I don't own!!!!
How do you get to the center of the u joint? How much grease does it take, meaning are we greasing the shaft or the u joint??
thanks Jamie
Old Jul 15, 2005 | 09:29 PM
nickleinonen's Avatar
it is a little larger than that... the fitting is about 7/16" around with the little 1/8" button in the center for the grease... i have seen a pic of it, but i don't remember if it was here or on the tdr...? i will try to find the link to the pic
couldn't find the pic i was looking for, but did find this
billmac
Sep 11, 2006 04:13 PM
tomm
18
Jun 23, 2006 03:48 PM
Gannetpeak1
Dec 3, 2004 06:25 PM
shaft
Jun 30, 2003 02:37 PM
bkay
Dec 12, 2002 05:22 PM
