lube front drive shaft fitting?
Old Mar 28, 2010 | 10:28 AM
  #46
tlloyd's Avatar
Originally Posted by nibroc
a regular zerk fitting will not fit---therefore the "fisheye"---not that hard to do w/needle adapter on flex hose and wifie holding bright flashlite and good luck w/wifie holding lite
Nibroc,,, With me telling her how to hold it I wo'nt begin to tell you where that flash light would end up..... Hope its not one that takes 6 D size batteries.
Old Mar 28, 2010 | 10:42 AM
  #47
bansh-eman's Avatar
ummm on the ground? Where else
Old Mar 28, 2010 | 12:01 PM
  #48
Country23047's Avatar
It's very hard to see.
Old Mar 29, 2010 | 07:55 AM
  #49
TedT's Avatar
I have trouble finding mine each time I grease the truck. For a first timer it might make it a little easer to find if the skid plate below the drive shaft was removed.
Ted
Old Mar 29, 2010 | 08:17 AM
  #50
troll3193's Avatar
I would also add that it helps to clean out the divot/fitting before trying to grease it...
I use a q-tip wet with brake cleaner... Without doing this first, I have had a hard time getting grease to go in...
Bryan
Old Mar 29, 2010 | 10:32 AM
  #51
Oregonian's Avatar
I'm still looking for mine, is there a fitting on both u-joints (front and rear) of the front driveshaft? Thanks.
Old Mar 29, 2010 | 12:45 PM
  #52
ssandlin's Avatar
Only on the rear cardan joint, no lube point on the front part of the driveshaft.
Old Mar 31, 2010 | 07:46 PM
  #53
Canuckville's Avatar
Westward (PN# WSWGN1) Grease Needle Injector fitting is the fittling you want to do the job. 1 1/2" long, 18 gauge. You can purchase from Acklands Grainger.
Old May 19, 2010 | 05:51 PM
  #54
pull-do's Avatar
Found it basically first try,,,, thanks for the tip and the photo,,,, already had the needle and flex hose grease gun,,,,
Old May 20, 2010 | 10:00 PM
  #55
Reelay's Avatar
My u-joint has a zert in it ,I had to use a needle lube attachment to get to the zert as the regular lube attachment was too big to pass thru the u-joint and yoke without pulling down the drive line. Is this the same lube point as you mentioned, or maybe what I have is a replacement u-joint with a zert installed instead of a little orfice plate. Also the other end of the driveline past the carrier bearing is a u-joint with a lube zert too. I lube them both at oil change time.
Old May 21, 2010 | 10:49 AM
  #56
Reelay's Avatar
OOps! Looked at the wrong d/L it is the transfer case d/L. I can not find the lube point yet but will keep trying. Mine also has the label under the hood to lube it with every oil change.
Old May 21, 2010 | 12:11 PM
  #57
Reelay's Avatar
Found the lube point after an hour of looking for it. Took several pumps of the lube gun to get the job done. Thanks for the info and excellent pictures!
Old May 21, 2010 | 01:52 PM
  #58
Polarlys's Avatar
Well, after having read this thread I decided that today, a nice day, was the day for me. Sure enough I found the sticker on the radiator support saying to grease the front driveshaft. I have an '06 Dodge 3500. Believing all the supporters of this forum to be up and up straight shooters I went looking for the elusive fitting just knowing that it was there. Sure enough after several minutes of scrutinizing the double joint very closely with a flashlight there it was. Doesn't look to have ever been lubed, everything around it was clean with just a surface coating of light rust. Other than the standard grease fitting I have several of the rubber tipped tubes in different lengths but none that would fit into the joint. Off to NAPA and to spend 7$ for not one but two needle fittings. I think Dodge must have part ownership of the company in China that makes this stuff. As I should have expected my first squeeze on the grease gun, the gun goes dry. Fortunatly I had a tube on hand so other than a brief annoyance I was back at it. So, after all that and trying my darndest I have NO IDEA if I got any grease into that joint. Got plenty around the fitting but don't know if any went in. I'm out of warranty so I guess it doesn't matter that at least it looks lubed. So I'm off to Colorado next month with my trailer, if the joint fails I'll pull the shaft and get a new joint installed, hopefully one that's easier to grease.
To all that have been frustrated by this effort. Keep lookin, it's way down there. But it is there. It's on the forward half of the double joint and the cross member is right in the way.
PS: on all the other U-joints there seems to be a cross pin through the yolk and the cups. Not sure about these could they be simply from the casting process ????? Any thoughts would be appreciated.
Thanks for all the advise, you've been right on the money.
Old May 21, 2010 | 02:45 PM
  #59
Reelay's Avatar
Polar, I got grease to come out after several pumps on the grease gun handle. The grease came out of the cups that are on the cross next to the transfer case output yoke. I think this is one of the few times it has been lubed. Luckily for me I had a needle grease fitting end that worked out just right to push the ball check in.
  #60
Fishguy 50's Avatar
the "pins" you see sticking out of the driveline yoke adjacent to the joint cups is the witness plugs of injection molded plastic. Plastic is injected into the yoke, it travels around a groove to retain the cups in the yokes. The witness plugs are there to prove the plastic traveled around the joint cup completely.
