lower than normal fuel pressure?
Old Mar 31, 2010 | 09:18 PM
1985cucv's Avatar
ok so i have a fuel boss mechanical pump on my truck and i noticed my gauge is reading 13 psi at idle. usually it is 17 at idle. i rev it up a little bit and it goes up to 20? do i have an issue? i dont know if my fuel filters are plugged? i installed a 2 micron less than 4000 miles ago it shouldnt be plugged already should it? i changed my canister mounted filter at about the same time something obviously isnt right here or is it? i run a baldwin 7977 in the canister but i think im going to go to wix for the fact that i have extra filtration with the cat filter what do you guys think? thanks
or could my gauge be bonkers its mechanical liquid filled? thanks
Old Apr 1, 2010 | 04:37 AM
Dodgezilla's Avatar
Fuel pressure senders seem to be prone to failure. I keep having ground issues with mine. Every couple weeks I have to pop the hood and wiggle the ground wires and then it will start working right again. Your gauge is mechanical but the sender is electronic, right?
Old Apr 1, 2010 | 05:24 AM
1985cucv's Avatar
no its an actual mechanical gauge
Old Apr 1, 2010 | 05:27 AM
1985cucv's Avatar
maybe the diesel is starting to eat at the gauge maybe it wasnt meant for it ive had that happen before. also gonna change the regular fuel filter to a wix since i can get them real easy
Old Apr 1, 2010 | 09:16 AM
Dodgezilla's Avatar
So you have actual tubing carrying fuel from the filter into your cab? That's a dangerous setup there....
Old Apr 1, 2010 | 08:58 PM
1985cucv's Avatar
no no no i have a gauge under the hood and its lower than normal
Old Apr 1, 2010 | 09:08 PM
1985cucv's Avatar
well figured it out gauge is junk
Old Apr 2, 2010 | 04:32 AM
Dodgezilla's Avatar
Glad it's just the gauge. Genos carries a setup for this if you prefer to keep it under the hood.....
Old Apr 2, 2010 | 01:58 PM
carl48's Avatar
dodgezilla it is not dangerous to carry fuel into the cab. all heavy equipment and large trucks for the last 60 years have it this way. i think a government worker from California must have come up with that one.
Old Apr 2, 2010 | 06:19 PM
Lost Lake's Avatar
Great idea.... NOT
Wix is NOT water separating. I wouldn't use a WIX, and I even like WIX filters. Chose a good water separating filter, Fleetguard or Baldwin and buy a case of them. Put the case in your shop, and they will be really easy to get because they are right there when you need them!
Old Apr 2, 2010 | 08:02 PM
Dodgezilla's Avatar
carl48, I don't think that having a line or gauge break while I'm driving down the road and spewing diesel fuel all over me is something I would want to have happen. It may not ignite from a cigarette but you and your truck are gonna smell for a long time. Not to mention that your initial reaction to fuel going everywhere could cause an accident. I'd say that's dangerous...
That's what I meant.
Old Apr 3, 2010 | 10:21 AM
1985cucv's Avatar
ok so no wix filter got it! what is the fleetgard part number? thanks
smog2001
Aug 10, 2007 09:32 AM
dhughe2
Jan 23, 2007 04:46 PM
06dmc
19
Aug 9, 2006 12:54 AM
OldSmokey
Mar 30, 2006 12:17 AM
royta
Jul 13, 2004 06:54 PM
