Lower and level
Old Jan 8, 2007 | 04:22 PM
scoggins's Avatar
Originally Posted by RamWheelsBy4
Best help I have seen. thanks
? will this like so many other things void warnty?
Old Jan 8, 2007 | 05:10 PM
Loco.Breath's Avatar
I can't see it effecting anything except driveline angle a little. If you lost a u-joint or something they might squalk about warranty. If they even noticed the spacer had been moved.
Old Jan 8, 2007 | 06:11 PM
scoggins's Avatar
How long will something liike this take?
Old Jan 8, 2007 | 07:25 PM
It shouldn't take more than a couple of hours at the most. Go ahead and pull the rear wheels off when you do it. You could do with them on, but it is much easier to get to everything with them off. Make sure you support the frame with good jackstands before you take the u-bolts off. It's not that bad of a job, just be careful, and recheck the torque on the u-bolts after the first drive.
Old Jan 8, 2007 | 07:50 PM
scoggins's Avatar
I won't need a torque wrench like the one needed to put 5th gear baxk on a 2nd gen. 5spd will I
Old Jan 9, 2007 | 01:08 AM
No, they're not that bad. I don't know the actual torque spec. I used a 1/2'' impact, and a breaker bar along with my calibrated wrist on my truck the last time. Be sure and run them down evenly when you do get the actual torque spec.
Old Jan 9, 2007 | 05:17 PM
scoggins's Avatar
thanks
loco
600 Megawatts
30
Oct 22, 2007 10:42 AM
smog2001
Aug 10, 2007 09:32 AM
04ctd
Mar 8, 2006 11:22 AM
teckert
Jun 9, 2004 12:34 PM
Cappy
May 26, 2004 05:05 PM
