Lower Egts with Turbo, best option
Old Oct 20, 2016 | 03:19 PM
TheNamesTopher's Avatar
HI there, I have an 05 6 speed with an edge juice with attitude, afe intake and 4in straight pipe and my egts are through the roof. Going up the mountain with an unloaded 2000lb trailer, I can barley keep her at 50 mph any faster and I'm hitting 1400 easy, I'm looking at doing a bigger turbo and wondering what would match best with the edge juice and lower my egts. I'll rip the edge out too if that's causing the problem.
Old Oct 21, 2016 | 02:23 PM
StealthDiesel's Avatar
What are your boost levels? That is always the 1st thing to check when EGT's are high.
If boost levels are low, you could have piping, joints or an intercooler leak, or turbo issues.
However, any interceptor type module is old technology and no longer a good option for these trucks.
The Edge J/A runs hot EGT's even on the lower levels.
For your 2005, even a basic Smarty programmer is a better choice than the Edge J/A.
Custom ECM tuning options now exists for these trucks which is the best solution. HPT and Smarty UDC Pro.
Remove the Edge J/A and all those harnesses. Purchase a good set of gauges, standalone or OBDII.
You will need a standalone boost gauge no matter what you do.
The stock MAP/boost sensor is only accurate for up to 35psi or so.
Old Oct 21, 2016 | 02:39 PM
My boost levels are good, normal. I've heard from a couple people about the smarty, whats the best option for my truck when it comes to the smarties?
Old Oct 21, 2016 | 10:57 PM
BILTIT's Avatar
Depends what you want. Smarty touch has a bunch of useful gauges.
Old Oct 21, 2016 | 11:17 PM
Your boost levels should be higher than "normal" with the Edge J/A.
Your boost levels should be 34-36PSI at full throttle up a hill.
As was mentioned, custom ECM tuning options now exists for these trucks which is the best solution. HPT and Smarty UDC Pro.
TheNamesTopher
Oct 23, 2016 05:35 AM
Hohn2
Oct 22, 2006 09:47 PM
Homer S.
Jul 3, 2006 11:40 AM
inline6359
14
Jan 4, 2006 09:23 PM
duallydave
May 29, 2005 09:35 PM
