loud clunk when i put in reverse from the driveshaft
Old Aug 6, 2007 | 01:54 AM
VikingDiesel's Avatar
just about everytime I go in reverse, a loud clunk from the driveshaft appears. could it be the rear pinion seal? since that is already leaking a little? I bought the seal just havnt put it in yet.
Old Aug 6, 2007 | 06:30 AM
tuzlo's Avatar
U joints ?
Old Aug 6, 2007 | 08:05 AM
Deesil's Avatar
Muted User
if it's coming from the rear end.....you've got trouble. Better hope it's u-joints. It would make sense that a bad u-joint or two mucked up your pinion seal.
Old Aug 6, 2007 | 08:07 AM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
My suggestion would be to jack up the rear , crawl under there and turn the rear tire to see were it is coming from . If the rear pinion seal leaked out all the oil you may have toasted the rear end but most likely it is u-joints , that would be my guess .
Old Aug 6, 2007 | 09:55 AM
stock03's Avatar
My truck also had a loud noise from the rear end. It turned out to be the ring and pinon. Covered under warranty. Now it's like a new truck!
Old Aug 6, 2007 | 12:57 PM
well, I know its not low on oil since I just did a diff flush 2 weeks ago and its a very small leak
Old Aug 7, 2007 | 02:03 AM
are the u-joints easy to replace and how many and how much are they and do I need?
Old Aug 7, 2007 | 02:21 AM
jwb600's Avatar
I put one in my 05 and it wasnt as easy as it looks, I thought it was a pain in the rear. sounds like you need to keep that thing out of the mud
Old Aug 7, 2007 | 02:25 AM
its only seen mud a few times and trust me, I am done with that and have been done with that for a whole, besides that little mudding incident a few weeks ago
Old Aug 7, 2007 | 03:39 PM
raychem's Avatar
Could also be the drive shaft, check the welds I had a similar problem.
Richard
Old Aug 7, 2007 | 05:53 PM
should the drive shaft have play where that transfer case is? Its goes in/out a little. Very little
Jturs
Oct 9, 2013 10:34 PM
Cummins610
17
May 29, 2010 12:50 AM
BLACKBIRD8200
Nov 2, 2007 12:39 PM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
