Looking at an 06 6 speed ?
Old Sep 28, 2012 | 07:13 AM
More Power's Avatar
I was wondering if this was a good year anything bad to look for i have been 2nd gen only till now. Truck is quad cab short bed 5.9 with g56,4x4 2500 with 79,000 miles
Old Sep 28, 2012 | 08:02 AM
Fiftygrit's Avatar
My 06 has been very good so far, replaced 2 seals in 115k, I do all the maintanance at what the book says, from what I have read the 06 and 07 seem to be the best of the 3rd gen`s.
Old Sep 28, 2012 | 08:11 AM
More Power's Avatar
Thanks i talked to the original owner its all stock retired gentleman just bought a 2013 and traded this one in.
Old Sep 28, 2012 | 11:43 AM
tantruck's Avatar
The 2006-07's with the manual transmissions and lower mileage are gettting tough to find. Especially an unmodified one. I had been looking for more than a year before I stumbled on my 2007 G56 4x4.
That being said. ----> I'd say go for it if the price isn't out of the world.
Old Sep 28, 2012 | 03:03 PM
rockcrawler304's Avatar
No issue with mine. Only real wheel seals at 30k miles but nothing since and have 113k miles now. Even the stock clutch still.
Old Sep 29, 2012 | 03:33 PM
More Power's Avatar
Well i got the truck it runs and drives great real improvment over the 01. Now to start looking for gauges and fuel filter setup any suggestions on that would be great.
Old Oct 2, 2012 | 09:49 PM
HBird98's Avatar
You aren't kidding about tough to find. After 2 years of searching, I finally found the truck in my signature. It only has 36,000 miles on it. Needless to say, I am .
Old Oct 3, 2012 | 02:39 AM
55_Cans's Avatar
Good going. If I had looked into it more, I would have got a standard and not the auto I have.
See if it had a steering linkage recall done, change the multifunction turn signal under warranty before 150,000 mi, check the fuel tank vents. Put a Baldwin BF7977 into the OEM housing and add a 2 micron filter after it.
Old Oct 3, 2012 | 08:32 PM
06dodge4x4's Avatar
Only issues I have had:
Tach doesn't work
On my third set of front hubs
Other than that been a great truck. Get a Smarty Jr. and enjoy!
Old Oct 4, 2012 | 12:55 AM
55_Cans's Avatar
Tach doesn't work
Did you try the tach fix DIY posted on the cummins forum? It works for most who try it.
http://www.cumminsforum.com/forum/3r...-issues-3.html
When you click on the link it takes a while to load, but it's a good DIY that is worthwhile trying.
Old Oct 4, 2012 | 05:22 AM
06dodge4x4's Avatar
Planning on trying it when I have the time.
Old Oct 4, 2012 | 08:42 AM
Reelay's Avatar
Got my 06 several years back has the 6 speed manual and some small mods done to it. Replaced clutch {pull a 13k fifth wheel} and had a new AC pump installed. The recirculation door had broken off from its hinges easy fix other than that it is a towing machine.
Old Oct 4, 2012 | 10:32 AM
jstone44720's Avatar
06 ad 07's are a personal favorite. The smarty's and other tuners are nice, but you have the option to go for efiLive on that truck. If you are going to get a tuner, that would be my first choice.
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
