Look at my trans filter
Old Dec 31, 2009 | 09:25 AM
RowJ's Avatar
Got a Mag Hy-Tec pan?
The 'deep dish' holds 4 additional qts (I have to add 11 qts w/ a filterchange).... and I think the regular Mag Hy-Tec hold 2 more.
RJ
no_6_oh_no's Avatar
Originally Posted by MoparNut
I replaced the gov. solenoid, pressure switch, and filter today. I was surprised at the amount of gray sludge I found. Is this normal wear.
The truck has 50k miles and I had the trans fluid replaced at 30k miles. This is the original filter with 50k miles.
BTW, the light throttle shift is perfect now.
If thats the first filter change then its pretty normal. The metal on the magnet is normal also for the first pan drop. These transmissions have a habit of making metal with the OE parts, doesn't hurt them it just seems to make more than others.
The gray film is metal dust also from the steels in the clutch packs. The OE steels do this normally.
The bottom of you pan isn't caked up with clutch material or a heavy layer of metal os its pretty normal for 50k.
Old Dec 31, 2009 | 09:34 AM
Lost Lake's Avatar
RJ
Nope... Standard issue. I let it drain for over an hour when I do a change, maybe that's it, otherwise I'll have to check the length of the dipstick.
Old Dec 31, 2009 | 09:39 AM
RowJ's Avatar
I know you have a different filter, but if anything like mine...it probably holds at least a qt. Will drip AFT for a long, long time!
RJ
Old Dec 31, 2009 | 02:39 PM
1985cucv's Avatar
i think it is normal looking i wouldnt worry about it!
Old Dec 31, 2009 | 05:10 PM
DBLR's Avatar
Mine took 6.5 qts to refill. Being the filter only cost me $18.00 plus tax at Dodge it gets replaced at every service per every trans re-builder I've talked to in the past 30+ years. I hate it when I see, hear dealers feeding people the BS they don't need to change the filter if the pay to have it flushed grrrrrrr, it needs to be replaced every 30K.
nvr-enuf
May 10, 2011 02:49 PM
smokeum99ta
MDDTR #33
Aug 17, 2008 10:40 AM
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
