Locktight or anti-seize ?
Old Apr 23, 2010 | 10:55 AM
knc77's Avatar
I replaced a rear brake caliper last night because the slides were hanging up on it. Should I put Locktite or anti-seize on the bolt threads?
At 11:00 pm in the drive, I realized I had the wrong Locktite if I ever wanted to take it apart again. Then I got to thinking with where those bolts are, maybe anti-seize is better.
Also read a thread where someone mentioned a shield for the rear brakes to protect the boots. Does anyone have a picture of one?
Old Apr 23, 2010 | 12:09 PM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Anti-Seize. Anti-Seize EVERY bolt and screw outside of the cab and even some in the cab if you live in an area where salt is king. If you ever have to replace front wheel bearings on that 4x4 anti-seze them. It'll make the next time you have to repair it and there WILL be a next time, easier then when it came off the assembly line.
Old Apr 23, 2010 | 01:58 PM
knc77's Avatar
That's what I got to thinking. We have enough salt here. Normally I don't worry about it because I don't own the vehicles long enough or someone else is doing the work. This truck will be around for a while though.
Old Apr 23, 2010 | 04:13 PM
ShouldBFishin's Avatar
I guess I’ll stand out as a dissenter here…
Assuming you’re talking about the bolts that hold the caliper on. Maybe I’m just paranoid, but I’d put a little bit of blue Locktite on them. Anti-Seize is a thread lubricant, those are not bolts I’d want backing off (or falling out - ).
Old Apr 23, 2010 | 05:53 PM
1985cucv's Avatar
antiseize every bolt you touch
Old Apr 24, 2010 | 09:20 AM
Lost Lake's Avatar
Anti-seize! Those babies get hot and rusty and getting them off can be a real PITA... I haven't had one ever come loose, and I've been anti-seizing for decades.
Old Apr 24, 2010 | 09:28 AM
madhat's Avatar
Administrator/Jarhead
Anti seize, and torque to spec. If you are really worried about it backing out, put some loc-tite on the back face of the bolt head.
Old Apr 24, 2010 | 09:41 AM
CD in NM's Avatar
Another vote for ANTI SIEZE, and as was said, everything exposed to the elements. Usually if you torque to the needed specs, nothing comes loose on it's own, well, maybe except for exhaust manifold bolts, and that's where you do the heads of the bolts with locktite.
CD
Old Apr 26, 2010 | 03:16 PM
knc77's Avatar
Thanks everyone. As soon as it dries up here, I plan to pull the wheel and check everything again. Won't take long to pull each bolt, treat with anti-seize and replace.
Old Apr 26, 2010 | 09:29 PM
DodgeDiesel61's Avatar
Yep.
Diesel Dave2
21
Apr 24, 2012 10:25 PM
jpajax
Jun 27, 2010 11:31 PM
BearKiller
Apr 2, 2007 04:52 PM
sadlerb_98
Apr 4, 2006 01:03 PM
JohnnyH
33
Jun 15, 2004 08:15 AM
