Limited slip stock front axle?
Old Nov 1, 2004 | 07:49 PM
FastZilla's Avatar
Randy's Ring and Pinon told me a week ago that there is nothing out for the 9.25" front end (axles, gears, lockers, hubs, nothing) until mid-2005.
Don't even know the specs of the front axle (axle shaft diameters. pinon diameters - I'm sure it's a FF....).
610 ft. lbs. plus through a locked front end with a 40" front tire stuck between rocks, 2.71:1 lo-range all going to that 1 stuck wheel can snap an axle (hopfully the u-joint first) - that is why the factory does not lock or LS the fronts... Or your tire is spinning fast and get stuck inbetween rocks and stops instantly...but the axle doesn't stop, it snaps.
The D-60 is a 9.75" axle - one would assume stronger as ring dia. = strength. They snap all the time rock crawling in light-weight rigs. Imagine and 8k lb rig....
I've seen many axles snap - all under extreme conditions add in beer and testostorone induced courage compounded by drunk spotters and buddies egging you on don't help either....
I believe the front locker the PwrWagon will be using is that new Eaton E-Locker (Electric actuated locker - push button). Purdy schlik...
Old Nov 1, 2004 | 10:36 PM
OOPS's Avatar
Originally posted by commando
Oops,
Actually the rear diff on the Rubicon is a LSD when unlocked and a full locker when activated electronically.
Thanks, I forgot about reading that in the specs. I do not pay a lot of attention to Jeep stuff, it is not that I don't like then it is just that I built a Toyota, down the road I may be building a Unlimited because I like wheelbase!!!!
MARF75
Oct 5, 2014 10:20 AM
rogerL1961
36
Nov 5, 2010 07:13 AM
shawn085
Nov 21, 2005 12:46 PM
Journier
Sep 23, 2005 03:41 PM
dkinzer
May 23, 2005 08:57 PM
