leveling kit problem
Old May 19, 2008 | 05:46 PM
MMarty's Avatar
Hey all, I just installed a 2 inch leveling kit on my 05 4x4 and now I have a loud popping noise coming from the frontend when I turn. also have a creaking noise when I hit a bump. I have checked everything and all my bolts are tight. The truck only has 22000 miles and was noise free before the kit. Any help?
Old May 19, 2008 | 05:57 PM
dslpwr81's Avatar
This is the exact same problem I had with mine. Tighten down the 3 nuts on the top of the shocks, and make them TIGHT! This is the same thing I went through. I really had to crank them down, but don't break them.
Old May 19, 2008 | 08:41 PM
rjm022's Avatar
did you disconnect the trac bar during install?? if so- double check the trac bar bolts- they need to be tight!
Old May 20, 2008 | 01:32 AM
chipmonk's Avatar
x2........
Old May 26, 2008 | 04:14 PM
MMarty's Avatar
Well, I took my truck to a friend that works for caterpillar and we used a big torque wrench on the track bar bolts and torqued them to 170 ft-lbs. Guess what? the popping noise is still there. I know it's the track bar because I loosened the bolts so the track bar was moving freely in the brackets and the noise went away. So now what? I will probably go back to stock rubber bushings and a drop bracket for the track bar to keep the geometry stock. I would go with polyurethane but they will probably sqeak too. Any thoughts?
Old May 26, 2008 | 04:22 PM
rjm022's Avatar
adjustable trac bar from don thuren. it will also recenter your front axle.
Old May 26, 2008 | 05:15 PM
chipmonk's Avatar
i think you have to do the pitman arm, if you do the track bar bracket. can never go wrong with don's adjustable track bar.
Old Nov 16, 2008 | 08:51 AM
stroker101's Avatar
i thought if the vehicle was raised 3" or more, then a aftermarket/longer track bar was needed?
just recently installed a 2.5" front leveling kit with no issues on my 06
Old Nov 16, 2008 | 09:20 AM
Rpainter's Avatar
did you reinstall the rubber spacer with the leveling kit??
Old Nov 16, 2008 | 09:40 AM
D45's Avatar
D45
Did you mess with the lower mounting bolts for the front shocks at all?
sgtdiesel
25
Jun 26, 2012 02:37 PM
blh1972
Jun 12, 2006 09:45 PM
dodgeboy59td
26
Dec 31, 2002 12:05 AM
UTAH
32
Dec 11, 2002 11:47 AM
j
17
Nov 10, 2002 07:57 PM
