Level Kit
Old Mar 26, 2007 | 11:53 PM
JWillms81's Avatar
Originally Posted by Rocky5.9
The only thing I don't like about mine happens to be the way the truck sits with a load. If you look at my gallery I have a picture with mine towing my brothers car. I think it makes the back look like it's squating too much.
They do make it look like they squat more. I do landscaping on the side out of my truck and everytime I load a palet or so of stone it make the truck squat bad but its just becuse the front is jacked up. Everytime I load down the back it puts the thought of airbags in my head.
JW
Old Mar 27, 2007 | 12:30 AM
mj007's Avatar
Originally Posted by berok
But maybe, just maybe I learned a lesson! But I dout it.....
I'm pretty good about the learning part it's the remembering WHAT I learned that's hard!
Old Mar 27, 2007 | 09:13 PM
pik's Avatar
pik
Just put on a Top Gun Customz leveling kit several weeks ago. No new shocks, no rough ride, no alignment, no death wobble, no problems. I did it myself with spring compressors in about 2 hours. Take a look!!
[IMG][/IMG]
Old Mar 27, 2007 | 10:27 PM
VaultRam's Avatar
When you used the spring compressor....did you still put the frame on jacks and lower the axle to get the springs out or did you just support the axle and use the compressor to remove the springs? Sorry for the question, just want to do it the easiest way!
Old Mar 27, 2007 | 11:49 PM
Luvnacumns's Avatar
I did both and you will have to lower the axle it has to compress a long ways before you can add another 2".. I cranked one side all the way up and put the coompressor in there and then let it down. Compressed the spring enough to take it out!
Shane
Old Mar 28, 2007 | 12:13 AM
VaultRam's Avatar
Thanks that makes since now that I think about it! Did you take the end links off or take any control arms off to make it easier?
Old Apr 1, 2007 | 09:12 AM
pik's Avatar
pik
Shocks, trac bar, and sway bar links were what I had to unbolt.
Springs came out fine, had to use the compressor to put the spring back in with the spacer on top.
Old Apr 1, 2007 | 11:11 AM
Luvnacumns's Avatar
I unbolted the bottom control arm and it got me about 2 more inches.. That was all I needed. Definately get it aligned. I had death wobble so I took it in and the toe was out really bad.. Got it fixed no DW....
Shane
JJCAMARO1952000
Jul 4, 2011 08:24 AM
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
