Lets talk about brakes
Old Apr 13, 2010 | 09:27 AM
.boB's Avatar
Did you resurface the rotors? During use, pad material is depositied on the rotor surface. That's part of the bedding in process, and they work better. If you change pad types, you need to remove that depositied material from the rotor.
I use a 120grit sanding disc in a drill motor.
If you follow the bedding in process to the letter, you'll get much better braking and longer pad life.
Old Apr 13, 2010 | 12:27 PM
ib516's Avatar
Nope, I just installed new pads. They are the same as the OEM ones, semi-metallic. Next time I do brakes (if I still own this truck) I will replace the rotors.
I used these pads
DIESELWRKS
14
Jun 1, 2015 12:13 PM
bws
18
Apr 9, 2005 06:53 PM
DaHammer
21
Jan 22, 2004 09:11 AM
dodgeman01
Mar 7, 2003 04:14 PM
midwestdually
Mar 4, 2003 11:56 AM
