Leak between trans & t-case
Old Feb 14, 2011 | 12:52 AM
quicksilvr's Avatar
Was under my truck today and noticed where the trans bolts to the t-case it had oil starting to seep on the bottom side. Any common issues here maybe? I am guessing it was t-case fluid b/c it was pretty dark and I just recently changed the trans fluid.
Old Feb 14, 2011 | 09:05 AM
cbrahs's Avatar
the back to back seals are leaking. there is 1 on the t-case and 1 on the trans.
Old Feb 21, 2011 | 01:09 AM
quicksilvr's Avatar
Was able to get a clean sample today, it's def. trans oil b/c it's not red. Any idea what's involved in replacing this seal?
Old Feb 26, 2011 | 06:37 PM
qwert's Avatar
You just have to remove the front and back driveshafts. You need to put a jack stand under the transmision for suport and remove the cross member. Then you can unbolt the t-case and pull it off. Most of the time it's the rear transmision seal and it's easy to replace . I bought mine from the dealer and it was $10.
Old Feb 26, 2011 | 06:48 PM
OldDodgeOwner's Avatar
Probably wouldn't be a bad idea to replace both of them while you have it apart.
wyododge
Aug 18, 2011 07:48 AM
wrenchmaster
Oct 6, 2010 10:00 AM
Derek Roch
May 20, 2010 12:16 AM
jrussell
29
Apr 30, 2007 04:32 PM
Lightman
16
Jan 21, 2004 10:46 PM
