Leak On #6 Fuel Line
I replaced mine a month ago.The mopar P/N posted above are correct.Parts are not that expensive.I think I spent 30 something dollars for all three parts.The fuel line comes with the plastic isolator same one use in '05 and later models.You need to replace one of the lift bracket bolt where the isolator clamp will bolt into.
Thank you so much for the info. local dealer had no idea what I was thalking about. By the way, I bought the truck with a bad motor. I have the motor apart, #3,4&5 cyl. walls and pistons bad. Block,head and crank at the machine shop, and it has a bad cam and 3 bad injectors.
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
trik396
Mar 9, 2006 04:40 PM
